Do Any pre-2001 ls1 Come Have the Upgraded Rod Bolts?
Old 10-11-2004, 03:28 PM
dug
dug's Avatar
Default Do Any pre-2001 ls1 Come Have the Upgraded Rod Bolts?
I just found out my 2000 ls1 has the later 2001 241 heads. Any chance that it has the better rod bolts of the 2001 ls1's?
Old 10-11-2004, 06:46 PM
Dragula's Avatar
I just pulled this from GM Performance parts online
12568734 Rod, Connecting, 1997-03
This connecting rod is used on all 1997-2003 production Corvettes and Camaros.
Technical Notes: 12568069 — LS6 Rod Bolts — These rod bolts have increased strength over all pre-2000 model year Gen 3 rod bolts. Recommended for use in all performance Gen 3 engines.
Therefore 2000 and up have the stronger rod bolts.
Old 10-11-2004, 09:23 PM
dug
dug's Avatar
Does pre 2000 mean excluding or including 2000? Anyway to verify with serial numbers? From searching it looks like the bolts were upgraded in 2001.
Old 10-11-2004, 09:45 PM
jrp
SN95 Director
jrp's Avatar
the rod bolts came from the ls6 plateform so i highly doubt 2k cars got them due to the z06 not comming out until 01.
Old 10-11-2004, 10:13 PM
SNW Vette's Avatar
Default updated bolts
The updated bolts were a result of Lingenfelter's ASA LS1 race engine program not the LS6.
Old 10-11-2004, 10:52 PM
jrp
SN95 Director
jrp's Avatar
just checked, your right. it says "...this particular change came as a result of the ls1's use in ASA race series during 1999."
wonder why they waited so long to put them into production vehicles.
Old 10-11-2004, 11:33 PM
pimpmaro's Avatar
So just to clarify for my own knowledge... this means that '00-'02 cars have upgraded rod bolts, meaning they're capable of spinning to higher revs without grenading? If anyone is very familiar with the subject, how high would you suppose one of these later motors could spin without requiring upgraded rod bolts (curious about the trex powerband)...
Old 10-12-2004, 12:09 AM
35th SS's Avatar
thats good to know at least my 35th has upgraded rod bolts.
Old 03-12-2008, 03:45 PM
Super Speed's Avatar
I know this thread is dated but is all this information true?
I hear 2000 yes 2000 no....
Old 03-12-2008, 09:45 PM
RE AND CHERYL's Avatar
I thought it was the 01-02 cars, the same ones that got the LS6 intake.
Re'
Old 03-13-2008, 02:54 AM
LilJayV10's Avatar
I have a 2000 and would kinda like to know this. I was going to replace the rod bolts and oil pump when I am doing the tranny this month.
Old 03-13-2008, 02:59 AM
2000Hawk's Avatar
I have only heard of the 01-02 cars having these stronger rod bolts. Its not an easy task changing the bolts from what i have seen, especially if the motor is still in the car. Its all on whether you feel you need to change them, because of mods coming/on the car or due to mileage.
-Joel
Old 03-13-2008, 03:05 AM
LilJayV10's Avatar
I am kinda looking at it as insurance. I hear the two weak points are the rod bolts and oil pump.
I drive the **** out of my car. I thought replacing these two things might help it live longer. I hear horror stories about the two going out but I don't know "really" how often it happens.
Old 03-13-2008, 04:38 AM
BLOWN SS/T's Avatar
I have a 98 and was going to do arp rod bolts but heard that they require resizing. So I said I was just going to leave them alone, but reading this would ls6 rod bolts be worth swapping into my 98?
Old 03-13-2008, 05:38 AM
james562's Avatar
Louis from LG Motorsports took a 98 Shortblock to 7100 daily and 7400 a couple of times on the dyno with 117,000 miles on it... I believe he said it was still running in a project car of his
But on another note I see plenty of threads of guys spinning a bearing with bigger cams like the G5X3,G5X4,MS4, MS3 and TREX that require being ran out 6800-7200 .... My only question is with 100,000-200,000 users on this board if we only see 10-20 threads a year about spinning a bearing maybe the odds are in our favor
Who knows in my case I think the 4L60 will go before my shortblock does
Seems like to me for every guy that had something go wrong theres 20 people with it working out just fine....
Old 03-13-2008, 05:39 AM
james562's Avatar
I've heard the Katech rob bolts are the way to go but they've been on backorder for quite some time now....
Old 03-13-2008, 07:48 AM
BigKap94z's Avatar
The newer rod bolts are the ones with the ferrules, my late year 2000 T/A with 241 heads had the newer bolts. Unfortunately I didn't find this out until I was pulling the rod bolts to replace them with ARP's.
Old 03-13-2008, 02:04 PM
bigsticksupra's Avatar
From the sounds of this, "pre 2000" would be anying before the year 2000. Can anybody with a year 2000 car confirm this?
Old 03-13-2008, 08:14 PM
Still waiting myself
Old 03-13-2008, 08:23 PM
Shawn MacAnanny's Avatar
I keep reading "ferrules" what does that mean? I had my shorblock out on a stand and no one could tell me how to find out if i had upgraded rod bolts or not when i posted the thread as i have 241 heads as well.
Quick Reply: Do Any pre-2001 ls1 Come Have the Upgraded Rod Bolts?
