What size valves are you using with your 427
Old 11-10-2004, 08:56 PM
CLIFFRSRAMAIR's Avatar
Default What size valves are you using with your 427
I need to know what size valves you are using in your heads. 2.02/1.60, 2.055/1.6. I don't want to use 2.08/1.60 as new seats will have to be installed. I was thinking of 2.055/1.6 valves. That brings me to my next question: What size cams are you running with this motors. Thanks
Old 11-11-2004, 12:31 AM
strokedls1's Avatar
I've got 2.055 1.60 valves on an iron 422ci. They work ok, but a bigger valve would probably work better. I did 490 something torque with an unlocked converter. Cam is a lunati 242 .595 112 lsa with 4 degrees advance (single pattern). Crazy low rpm power, and speedo picks up about as quick as the tach.
Old 11-11-2004, 04:40 AM
11 Bravo's Avatar
Set your heads up right, you'll be glad in the long run with 2.08's. Look at cams in the 24*-25* duration.
Old 11-11-2004, 07:44 AM
nitrorocket's Avatar
2.15/1.625 ( But its a SBC)
Old 11-11-2004, 08:37 AM
Brian Tooley Racing's Avatar
2.10/1.60, if you can afford a 427 then $160 for seats should be no problem.
Old 11-11-2004, 09:28 AM
Wow, those are large valves. Did you having any valve to piston clearance issues? What pistons did you go with? I was more concerned with this problem than the expense of replacing the seats. Thanks.
Old 11-11-2004, 09:55 AM
11 Bravo's Avatar
FWIW, I was told by a reliable sponsor that 2.08's were plenty big for a 427 and running a 2.10 is kinda overkill. But I'm sure Tooley knows what he's talking about as well.
Old 11-11-2004, 12:09 PM
427 LS1's Avatar
I have 2.100/1.600 342 cfm @ .625 lift and 248 cfm on the exhaust.
