What causes timing to jump while decelerating w/no throttle?
Old 11-12-2004, 11:23 AM
Another_User's Avatar
Default What causes timing to jump while decelerating w/no throttle?
What cause that to happen? I thought the PCM was supposed to use the base table, but instead it will do that for fractions of a second, and then drop to some much lower number (10 degrees or more soemtimes), then jump back up. Pretty much, it does whatever it wants.
Old 11-12-2004, 12:31 PM
HumpinSS's Avatar
Are you sure this isnt DFCO. while the car decels in gear and hits DFCO timing will drop to 0 and injector pulse widths will also drop to zero. Once it crosses the lower threshold timing and fuel will resume
Old 11-12-2004, 12:39 PM
It never hits zero. I'll do a log later of injector pulsewidth. Is it possible that it is jumping in and out of DCFO?
Old 11-12-2004, 12:56 PM
HumpinSS's Avatar
Well it takes a sec or two for it to enter so i doubt it is going in and out. A log will tell you better. It also goes in to OL when it does the DFCO thing, just an FYI
Old 11-12-2004, 01:16 PM
Hmmm. That would make it really sensitive to VE changes wouldn't it?
Old 11-12-2004, 01:35 PM
HumpinSS's Avatar
No because the trims stop learning in open loop mode. and will populate with 0's if i am understanding your question correctly
Old 11-12-2004, 01:42 PM
I don't think I have ever seen my trims go to zero while decelerating. I must not be going into DCFO. If I post a log will you take a glance at it?
Old 11-12-2004, 10:16 PM
Well I just checked, and while I am decelerating my injectors are still firing, and my timing is still going. That sucks.
Old 11-12-2004, 10:20 PM
HumpinSS's Avatar
I am out of ideas give me a few to think about it
Old 11-13-2004, 04:56 AM
gameover's Avatar
timing ramps down before the injector cutout, you may not be reaching the injector cutout before DFCO disables and timing kicks up again.
Old 11-13-2004, 08:20 AM
Well I went back in to my tune and went +10 kpa on my DCFO entry and exit because I have not seen DCFO cut in since my cam install. I was always wondering where my popping on decel went. I will see if that stabilizes my decel, or if I need to change the values again.
Old 11-13-2004, 02:12 PM
Aha. Now DCFO works again. I think I need to add a little more air in the throttle cracker tables now for my surging...it's a little better, but I still have a little bucking. I think it is better for the car to cruise a little than to buck like a bull...
