Aftermarket cam and low RPM's ?
Old 11-15-2004, 08:11 PM
TheBowtieboy's Avatar
Default Aftermarket cam and low RPM's ?
I have been told that running an engine, under load, is really not good under 2000 RPM's with an cam upgrade.....I'm talking 1500 - 2000 RPM's
Any information pro or con to this ?
Old 11-15-2004, 09:39 PM
xttc2000's Avatar
it lugs the motor and bucks a little, get a tall gear and you wont have that problem.
Old 11-15-2004, 09:58 PM
jrp
SN95 Director
jrp's Avatar
or a proper tune.
Old 11-16-2004, 08:33 PM
More to the point of my question; is it hard on the engine itself ?
.....not interested in symptoms but the effects.
Old 11-16-2004, 08:54 PM
Another_User's Avatar
I'm sure it isn't good. But I have never heard of an engine that actually died because surging or bucking caused a mechanical failure. I think it is more annoying than anything. A good tune will not always help. I have been tinkering with the problem for awhile, and I can't nail it down to spark, fuel, idle airflow, or a throttle transition problem. It is a real PITA.
Old 11-16-2004, 09:22 PM
Yeah, my car was tuned with my 1st cam, and will be tuned with my new one, but curious if driving down the highway in 6th @ 1700 RPMs is harder on the engine than running 2300 RPM's in 5th gear.
I was once told that driving below 2000 RPMs is not really good for the engine.
Old 11-17-2004, 05:30 PM
I believe that.
Old 11-17-2004, 07:46 PM
luv2spd's Avatar
I don't see anything wrong with cruising below 2000 rpms. I do it all the time, but I do downshift to pass!
Old 11-17-2004, 10:19 PM
8POTS's Avatar
Nothing wrong with cruising at 1800 or so rpm here and there. Just as long as you do some WOT here and there too.
A motor that spends most of it's time on light loads and at low rpm are more likely to have bore glazing problems down the track.
