ARP head studs > 6 or 12 point best?
Old 11-22-2004, 04:55 PM
V8er's Avatar
Default ARP head studs > 6 or 12 point best?
I am ordering ARP head studs for my LS1. Does it matter if I get the standard hex 6pt or the 12pt? The 12pt is more money but are they better?
Old 11-22-2004, 05:01 PM
Bo White's Avatar
The 12 point nuts are lighter(not a big deal, couple of grams) and have more contact on the socket for better grip.
Old 11-22-2004, 05:40 PM
C4VetteLS1's Avatar
either will do fine....i prefer the 6pts
Old 11-22-2004, 05:43 PM
Beast96Z's Avatar
The 12 pt's also distribute the load across the nut better. Of course you need a 12 pt. socket also.
Old 11-22-2004, 06:02 PM
V8er's Avatar
Yikes you guys are getting very fussy about these ARP parts! I think for my sub-1000hp LS1 the studs with 6pt nuts will be more than enough
Old 11-22-2004, 07:00 PM
pdd
pdd's Avatar
i got the 6pt because of more bite on the nut
Old 11-22-2004, 07:22 PM
NA$TY-TA's Avatar
12 pts here because at the time the 6 pts were backordered....
Kyle
Old 11-22-2004, 11:54 PM
Restricted User
CAT3's Avatar
pdd, technically speaking 6pt has less bite, less contact area for torque applications. 12pt distributes loads more even, and have greater surface area.
Unless you are going extemely wild 6pt are more than enough.
Old 11-23-2004, 03:15 PM
technical's Avatar
That's why they make washers.
Old 11-23-2004, 04:43 PM
GuitsBoy's Avatar
I think they mean it as more contact with the socket. Since only the edges closest to the corners actually make contact, having more corners means more contact. IIRC, ARP nuts and bolts have round washer bottoms anyway.
If you still torque both to the same torque spec, whats the difference? Like it was said, maybe a couple of grams less mass across the entire set.
Old 11-23-2004, 04:59 PM
technical's Avatar
What do you mean by round washer bottoms?
Old 11-23-2004, 05:00 PM
Bo White's Avatar
I like round washed bottoms......
Old 11-23-2004, 05:01 PM
GuitsBoy's Avatar
Sorry, Brain Fart. The threads about studs. I was thinking nuts / bolts.
Old 11-23-2004, 05:30 PM
pdd
pdd's Avatar
ME TOO
Old 11-23-2004, 05:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
I like 6 point's because there is less chance of stripping the nut.(wrench side)
Old 11-23-2004, 07:17 PM
LSX Mechanic
Damian's Avatar
6pts by far....
Old 11-23-2004, 08:43 PM
jrp
SN95 Director
jrp's Avatar
i went 6pt because of the price.
Old 11-24-2004, 07:51 AM
SideStep's Avatar
Same here......
Old 11-24-2004, 08:00 AM
GuitsBoy's Avatar
I actually think this is backwards. Since its only the corner that contacts te wrench, 6pts have a greater chance of rounding off than 12 points do. Can somebody back me up here?
Old 11-24-2004, 08:03 AM
Bo White's Avatar
I already have. The points are like splines of an axle, more spline count-more contact. Also like threads, fine threads are stronger than course threads.
Quick Reply: ARP head studs > 6 or 12 point best?
