Help separating stock Y for cat-back!!
Old 11-22-2004, 05:42 PM
Uno99's Avatar
Default Help separating stock Y for cat-back!!
Any tips or tricks to help separate the stock y-pipe from cat-back. IT IS STUCK TOGETHER. I don't want to cut it.
Old 11-22-2004, 06:09 PM
01TAFlyer's Avatar
I took off my old cat-back in one piece and to break that connection I:
First covered the joint in wd-40 and let sit for 30min-1hr
Then after the cat-back was loose I vertically twisted it up and down till it came off (a friend makes this much easier- each person grabs one side)
Hope this helps, it can be done, just takes some effort.
Old 11-22-2004, 06:18 PM
Uno99's Avatar
Is there any other penetrating lube I counld use?
Old 11-22-2004, 07:27 PM
Uno99's Avatar
Anyone??
Old 11-22-2004, 09:45 PM
Keenov's Avatar
Maybe some PB Blaster or White Lithium (doubt that will work as well for this type of situation).
I had to torch it. Heated it up for a little and it slide right out.
Old 11-22-2004, 09:47 PM
Z28Venom's Avatar
Ditto..
We used a Propane Torch to heat it up, and alot of wiggling.
Old 11-15-2007, 02:50 PM
mikenews's Avatar
PB blaster from wally world!
Old 11-15-2007, 02:52 PM
Ace$nyper's Avatar
liquid wrench pb blaster wd40.
Old 11-16-2007, 11:51 AM
tim99ws6's Avatar
wow,
raised from the dead....
Old 11-16-2007, 04:10 PM
jetlag's Avatar
Hahaha.. wow, very old thread diggin'...
Anyways, I could never get the stock Y-pipe seperated easily..so I used a special method.
Sawzall.
Old 11-16-2007, 04:51 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
Sawzall.
EXACTLY.
Old 11-16-2007, 05:13 PM
SamhainZ28's Avatar
i smash it off with a big F*ckin hammer
Old 11-17-2007, 08:38 PM
2formulas's Avatar
it's been 3 years, do you think he got it off yet?
Old 11-18-2007, 02:13 PM
tim99ws6's Avatar
naah, probably just ran a new catback right beside of the old one. You know what they say:
If one is good, two has to be better!
