ah, the age old question...which pulley??
gonna get underdrive crank pulley. thinkin about ASP. dont know any other kinda, well havent hear or read about them in the search (yes i searched this)
new one from them has no issues with double roller right?
from the reading i see they are good, but if anyone thinks otherwise let me know. which sponsor sells them the cheapest?
11 Second Truck Club
The ASPs are a good pulley. I went with the March for the sole purpose of it being fluid dampened. My rev limiter is set at 6600rpm's and since the pulley swap it revs better on the top end.(a little smoother)
I don't think you'll go wrong either way. I'd say stick with either ASP or March.
I got my March at Skoggin Dickey for $189. I'm very happy with it. As for the ASP, I'm not sure I just know alot of people run them and like them.
The March is heavier than the ASP, but on the upside it does dampen better for cars with alot of mods.
Maybe someone with alot of mods can chime in that has the ASP. In my case the March was a better alternative. You could probobly get the ASP and have 600rwhp and be fine for all I know.
I don't want to steer you either way because the difference in most cases is probobly minimal. Good luck! My lunch's over.
Originally Posted by pewterta
not a worthery mod...id get something else
an underdrive pulley IS a worthy mod as it frees up the crank by minimizing the drag applied on it. asp and march are the two top names that are under $300. next step up is ATI Damper but that is BIG $$$...best in the business tho. personally i'm going with a march fluid dampened pulley when the time comes, i have heard great things about it, nobody has had any issues with knock or belt slippage, and while its about the same weight as stock, the fluid on the inside remains motionless so it shouldn't be calculated as rotating mass.
ASP and March pulleys here
http://www.thunderracing.com/catalog...vid=3&pcid=111
Looks like a good deal on the march pulleys right now.
