NY emmisions test..
the "emmissions" test is pretty simple. cars 99-01 will pass if there are no check engine codes present in the computer, or its memory. Along with that your computer has different monitors, you can fail up to two monitors and still pass.
on 01-up everything is the same except you can only fail one monitor. no sniffer or nothing
I guess It would depend on the shop. We still have to do a Visual to check for all installed emissions parts. Here's a quick note FYI. Alot of the shops have started to become **** about stuff, mine included. At my shop you would not pass. Later John
Thanks for the info guys. And to James99ws6 for pointing out my typo,,,,
I found the answer on the NYS DMV website.
http://www.nydmv.state.ny.us/broch/c-50.htm
One quote from the site...
"The inspection station is required to advise the Customer about the OBD check results, but cannot fail the vehicle's inspection based on those findings."
That is not correct............................ That is wrong it has not been updated since 02 things have changed..... Do a search for NYVIP its on the DMV homepage....... Later John
If you use a shop with a decent guy you might get away with it. The Place where I go said he wouldnt have a prob as long as he can do a quick visual and see that there are cats there.Its time for me to go to the junk yard and get some converter covers.
