installing underdrive pulley
i see it says to measure how far its gone in? can you just put the pulley on and tighten to 240 ftlbs back it out and then re tighten to 37 ft lbs and then do the 140* turn after that?
should this all be done wiht the new bolt or not until the 37 ftlb part? thanks
what kinda special bolt?
http://img.photobucket.com/albums/v4...4/000_1007.jpg
http://img.photobucket.com/albums/v4...4/000_0990.jpg
where can i get it and what size is it?
That's what she said...
iff 200 degrees works, 400 should work twice as good
i heated the axle bearing carrier from my 4 wheeler to about 500 degrees (forgot it was in the oven) and the bearings went in the freezer. they would go in so easily, that i couldnt get one side to stay in so i could put the other side in lol. one kept falling out while i put the other in.
