need help i broke my pump
Old 12-26-2004, 10:24 AM
sr_ryan1's Avatar
Default need help i broke my pump
okay i fucked up and didnt install my converter all the way, and it broke my pump, is this somthing i can fix my self or should i take it to a shop, if i do it my self where can i buy the pump? and how much dose it cost? thnaks
Ryan
Old 12-26-2004, 05:15 PM
sleeperstyle's Avatar
i had trouble getting the pump housing bolts to break loose (on the inside of the bellhousing).- after the fact i realized that i didn't need to take the pump out anyway...
if you can get them off, then i don't see why you couldn't replace the pump if you had a service manual. although- im not sure if it is connected to anything integral and you would have to take the whole trans apart.
i say call up a local trans guy and ask how hard it is- maybe try a few different guys since they may lie and say it is difficult and let them do it for alot of $.
good luck.
Old 12-26-2004, 08:14 PM
Ragtop 99's Avatar
A pump only is a few hundred dollars at a tranny shop; a bit more if you put a new one in. while it's apart you might about whether you want new clutch packs and bands.
Old 12-26-2004, 09:10 PM
68birdls1's Avatar
the same thing happened to me, and instead of fixing that trans, i found a built trans for about the same price! so i really lucked out, but i would say you might want to look around at the for sale section. good luck though
Old 12-26-2004, 09:52 PM
jxaxsxoxn's Avatar
Did you see my reply about this on your other post about this?
No offense but if you cannot install a converter don't mess with the pump, have someone else do it.
So what broke in the pump?
You could probably take the pump apart and replace the rotor, vanes and rings. Or have someone else replace that stuff.
Old 12-26-2004, 11:43 PM
35th SS's Avatar
while your in there might as well replace 3-4 clutches,heavy duty band.servos and remember next time 3 clicks on the converter.should be all the way in.good luck.
Old 12-27-2004, 12:37 AM
99ssleeper's Avatar
There is a pump available that has more vanes, you might want to look into it.... www.4l60-e.com
You can also measure to the mounting flanges on the converter to see if it is in the trans all the way. Lay a straightedge across the trans bellhousing on the face that meets the engine, then measure down to where the converter will contact the flexplate.....it should be 1 1/8".
Old 12-30-2004, 09:12 PM
sr_ryan1's Avatar
thanks for all the input everyone i took it to a trans shop they installed another pump $150, but another question i have is the tourq converter bolts are to long for this vig converter, and iv had to cut them, GM # is 11589040, does anyone know the right ones to use?
Old 12-31-2004, 10:54 AM
jay_99z's Avatar
Good luck with everything and you aren't the only one to tear up a pump that way
