take a look at these flow numbers.......
Old 01-04-2005, 09:34 PM
pbjones81's Avatar
Default take a look at these flow numbers.......
The person that flowed my heads today didnt have a 3.9 bore (I am told that is the standard for our LS1's??) so he used a 4.00 one at 28". is there any way to convert the flow numbers I have to 3.90 specs to compare with other heads? here are the numbers that we got. also, can someone critique these numbes for me too? good? not so good? i dont know a lot about how to read them. thx
lift int exh
.100 67 57
.200 131 111
.300 190 150
.400 244 182
.500 281 204
.600 311 213
Old 01-04-2005, 09:44 PM
jrp
SN95 Director
jrp's Avatar
so where did you finally find a place to flow them? those numbers are in line with what PP advertises once you minus a few cfm going down to a 3.90 bore. Check the PP review thread i started for more info. in all honesty those numbers dont tell you a thing.
Old 01-05-2005, 01:19 AM
Nate_Taufer's Avatar
exhaust side looks weak
Nate
Old 01-05-2005, 04:16 AM
TVWilkes's Avatar
3.90 bore will lose about 7-8 cfm in the high lift numbers.Was the exhaust flowed with a pipe?
Old 01-05-2005, 12:02 PM
pbjones81's Avatar
no there was no pipe on the exhaust....can someone inform me what difference the pipe on the exhaust will make? Logic says it will make the flow numbers go down more, but lately Ive been wrong several times while using "logic"
Old 01-05-2005, 12:08 PM
pbjones81's Avatar
jrp, i found a small (but very experienced) race shop about 3 hours north of my house. Just north of Springfield, MO. apparently he is the only person with a flow bench in the area..... At least thats what I was told.
Old 01-05-2005, 12:12 PM
gomer's Avatar
How much did they charge you to flow them and how many different cylinders did they flow?
Old 01-05-2005, 09:05 PM
pbjones81's Avatar
$40 and 1 cylinder......glad to see youre still around gomer, I havent been in a long time cause Ive been so busy at work.... Am I reading your sig incorrectly, or did you switch brand of heads? see ya
Old 01-06-2005, 04:26 AM
TVWilkes's Avatar
A pipe will add about 10-15cfm in the higher lift numbers.
Old 01-06-2005, 06:35 AM
gomer's Avatar
Yes, I switched over to the PRC's. I sold the TSP/Patriot Raceport heads that were on my car and when I bought again, I decided to try out some of the PRC's.
Let us know how your combo turns out.
Old 01-06-2005, 06:16 PM
383ss's Avatar
you low/mid lift numbers look pretty weak on the intake side
Old 01-06-2005, 08:14 PM
mr2guru's Avatar
Those #s are right in line with the spec sheet on my MTI stg2E heads I just got. Flowed 28" 3.90
