Mustang GT vs. Z06
Mustang GT vs. Z06
Ok, so a guy I (unfortunately) know has an '03 Mustang GT auto with headers, full exhaust, 4.10's, throttle body, chip etc. Your usual bolt on car. Obviously right now he's not even a brief concern of mine, however he says hes gonna get a 3500 stall, NX 100 shot and what he called "Stage II Cams." He says he runs 13.6's @ 101 mph now (never seen a timeslip so I dont know for sure) but I'm wondering what he'll run/trap at after all his proposed mods. I know this guy is gonna get this stuff - I'm pretty sure hes not a bullshitter.
So what will this guy run and trap at? Am I safe, and if not, what mods do you think I will need? I'm feeling a 100 shot is good cheap insurance. (All he needs to know is its stock )
Thanks
Thanks
Originally Posted by unit213
It's composite.
And the Z-06 will loose badly...
A buddy of mine has a 2000 M5 GT and runs 13.8's with a couple bolt-ons. Hes one of the best drivers ive ever ridden with. On a 75 shot and slicks (not D/R's) he ran a 12.8. I think his car might be a bit of a freak. Its his DD so he doesnt even think its a quick car but its decently fast for what it is.
Originally Posted by ChaseN
...'03 Mustang GT auto with headers, full exhaust, 4.10's, throttle body, chip etc. .. hes gonna get a 3500 stall, NX 100 shot and what he called "Stage II Cams." He says he runs 13.6's @ 101 mph now
... I'm feeling a 100 shot is good cheap insurance. (All he needs to know is its stock ) ..
Thanks
Thanks
Originally Posted by BLACKTURBOS2K
I work in Tysons! what have you ran at the track?
Originally Posted by 00GTBlown
Of course if you spray he's finished, and it should be pretty obvious to him you're modded if you do.
Originally Posted by DMNSPD
There's some weird technical term for what the manifold is made of, but it's a composite plastic.
Pilfered without remorse from the "Millenium Motor" article
Specifically, it’s a Dupont material called "Nylon 66" that is a mixture of a Nylon and glass fiber reinforcement.
1997 Corvette® LS1 V8 engine has a fuel-saving injection molded nylon air intake manifold. Key benefits of the one-piece, thermoplastic manifold are weight reduction, improved engine performance and reduced manufacturing costs. The manifold is molded of Ultramid® glass fiber reinforced nylon 66 resin.
Thanks
Thanks
BTW the composite intake can take it for a while
With his upcoming mods he'll be capable of beating you in a drag race, but it's no guarantee. He'll have to get far enough ahead on the low end so you don't catch up. Of course if you spray he's finished, and it should be pretty obvious to him you're modded if you do.
Originally Posted by cantdrv65
You should still be able to take him fairly easily even with the 100 shot.... What kind of times do you run with the Z as it sits?
