Breaking spot welds?
For a bit of weight reduction I'm in the proces of removing some of the excess brackets / mounts that I'm not using anymore, i.e. where heat shields and seatbelts used to be. My problem is that I don't have a good method for breaking and removing the spot welds.
For example, I removed one small two-weld bracket from underneath the car using a hammer, chisel, and prybar. One spot weld broke and stayed on the car, the other broke and ripped a small hole clear through to the carpet. Not exactly what I wanted, and now I get to play "patch".
So how would you guys do it? Hammer + Chisel? Prybar? Dremel? Angle grinder? Forget about it entirely?
Yes the cutter is a small drill bit with a cutter at the top that eats the top of the weld! Go with the air hammer! My friends own a boady shop so for realy cheap we blasted them of. Takes only like 1-2 minutes.
I am sure a local body shop would remove them for real cheap. Or any good fab/roll cage shop has these tools.
