Saw this On Ebay
Old 01-13-2005, 07:15 PM
chase311's Avatar
Default Saw this On Ebay
Hey guys i came across this on ebay and was wondering WTF it is and is it really Necessary... http://cgi.ebay.com/ebaymotors/ws/eB...category=33613
Old 01-13-2005, 07:25 PM
LSUxBlake's Avatar
Not necessary on anything I can afford
Old 01-13-2005, 07:52 PM
Crazy Man's Avatar
Looks pretty cool if I had my motor out I would try it.
Old 01-13-2005, 07:54 PM
SPANKY LS1's Avatar
Waste of money. Many many 700+ RWHP and 8 and 9 (and soon to be 7) second stock blocked cars without this girdle.
Old 01-13-2005, 08:04 PM
TrendSetter's Avatar
lots of people have sex without condoms too
Old 01-13-2005, 08:07 PM
69firebird's Avatar
I dont think that this is worth it, alot of cars are runnig without them. It all depends what your goals are, W2W is using them on their 1200+rwhp cars.
Mustang guys have been running these for years, because it helps the block strength, but again they are only 2 bolt mains, if your going all out ***** to the walls might as well get it
Old 01-14-2005, 06:09 AM
Smoke T/A's Avatar
What is W2W????
Old 01-14-2005, 06:30 AM
Parker TX's Avatar
Wheel2Wheel. Sponsers.
Old 01-14-2005, 11:09 AM
BTL FED's Avatar
If you go to his site, at the bottom of the add it says call for price of custom ARP main studs, So I guess if you buy this, then you have to buy a set of custom ARP studs to make it work
Old 01-14-2005, 12:27 PM
GuitsBoy's Avatar
Cant I do the same thing with some washers from home depot? Forgive me for not seeing how a thin plate of .25 steel (i assume its not aluminum) is going to further strengthen those already beefy six bolt main bearing caps.
-T
Old 01-14-2005, 12:54 PM
snketr's Avatar
www.catpep.com They make one to, it is cheaper.
Old 01-14-2005, 04:37 PM
ktmrider's Avatar
Not a bad idea for aluminum blocks but then again you'd need to see some serious HP to actually require it.
More peace of mind if you can afford it....
Old 01-14-2005, 05:59 PM
The Guy in MY 99TA's Avatar
I like the idea of it and have considered it on my sbc and some big block projects. But that girdle really isn't quite thick enough for my likings, now 3/8's or 1/2 inch would be IN like FLYNN.
Josh S.
Old 01-23-2005, 10:16 PM
texasuperman's Avatar
seems like a waste of money
