how much fuel line to order??
im going from tank up to rails with -8 and with a speed inc fuel filter
and - 6 on the return with speed inc fuel rails
i ave the same y-block set up as mighty mouse
i just need an idea on how much feet of line to order ? and one have a clue on how much -8 or -6?
thanks!
thanks!
i think i got 20 also, have some left over.. im sure it will come in handy one day.
the best way to cut it is wrap over where you want it cut with duct tape and then cut with a dremel and a cutoff bit. if you cant do that use a hacksaw.. have to be careful to keep the braids tight or it will never fit.
thanks i just ready to order everything im just looking for this last fitting
that goes from my -8 line into my -6 regulator
i need a -8 hose end with a -6 male
if you have the speed (cas) regulator.. apparently now they carry both the -6 and -8 fittings for the regulator, you get that and you wont have to use an adaptor.
if you are using a section of -8 for the return line i would def. get 20'
thanks dave once again you help me out
does speed have these fittings for the reg?
