Best oil to use?
Old 01-25-2005, 11:04 AM
freakynipples69's Avatar
Default Best oil to use?
not sure if this is the right forum but currently I use mobil1 5w30 oil. Should I keep using 5w30 or upgrade to maybe 10w30? check my signiture for mods and very near future mods.
Old 01-25-2005, 11:06 AM
Fulton 1's Avatar
You'll get a ton of opinions on oil. My .02 would be to do some research over at Bob's. link - http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old 01-25-2005, 01:18 PM
Redlinez's Avatar
I've been hearing hype about Castrol Syntec fully synthetic made in Germany. 0-30w I believe. I just haven't looked hard enough to find it. You can't go wrong with Mobil 1 5-30 syn though.
Old 01-25-2005, 01:42 PM
BlueSix's Avatar
Mobil 1 5x30 is reccomended from the factory. I have heard great thing about the German Castrol 0w30, but i haven't found it around here yet, so i'm putting in the mobil 1 stuff.
Old 01-25-2005, 01:57 PM
SSCamaro99_3's Avatar
Amsoil, Redline, and the new Castrol seem to be the top tier.
Old 01-25-2005, 02:06 PM
Rhode Island Red's Avatar
there is some new oil about to hit the market, this stuff might be worth getting
we did some Engine testing on the LS1 and Mobil 1* and it was amazing can we say 30,000 miles without a drain.
Here's the new line up:
http://www.mobiloil.com/USA-English/...Oils/Oils.aspx
Old 01-25-2005, 02:13 PM
INTENESS's Avatar
I would highly recommenend the Germen made Castol 0-30 made me a believer
Auto zone has it
Old 01-25-2005, 02:27 PM
Tech Addict
Rokko's Avatar
The german castrol 0-30 is good stuff, if you can find it. I run the M1 0-40 since I can't find the castrol.
Old 01-25-2005, 02:44 PM
zamboxl's Avatar
Auto zone has it
o man where do you find that stuff, the AZ's down here dont even know what i am talking about.
Old 01-25-2005, 03:17 PM
Joker's Avatar
I run Mobile 0w-30 with no probs, excellent milage...good stuff.
Old 01-25-2005, 05:33 PM
CaMaRoZ28LS12000's Avatar
castrol 0W30 here
Old 01-25-2005, 05:49 PM
01TAFlyer's Avatar
Mobil 1 5w30 syn here. I have had the best luck with this of the different viscosities I have tryed.
Old 01-25-2005, 06:19 PM
2000Firehawk's Avatar
ExxonMobil rolls out longer-lasting motor oil
By Lisa Sanders, MarketWatch
Last Update: 4:06 PM ET Jan. 25, 2005
DALLAS (MarketWatch) -- ExxonMobil said Tuesday it has developed a new line of motor oils designed to extend the length of time needed between oil changes.
The integrated oil and gas company (XOM: news, chart, profile) said that the oils guarantee protection and performance for a minimum of 5,000 and up to 15,000 miles.
The company said consumer research found that half of all drivers wait more than 3,000 miles to get their oil changed, and close to 90 percent of those surveyed indicated they would use a motor oil that's guaranteed for up to 7,500 miles.
"Consumers have told us that while they may not necessarily go 15,000 miles between changes with Mobil 1 Extended Performance, they appreciate knowing that the level of protection they're experiencing can go the distance," said Mike Mullins, the vice president of marketing for ExxonMobil Lubricants and Specialties, in a statement.
Old 01-25-2005, 08:30 PM
Mike98WS6's Avatar
Sounds very interesting.
Old 01-25-2005, 08:54 PM
FatZ28's Avatar
Might give Patman a ring, hes the expert on the black stuff.
Old 01-25-2005, 10:13 PM
BlueSix's Avatar
The Castrol is actually green.
Old 01-26-2005, 12:56 AM
m_donze's Avatar
Castrol syntec 0w30 here. You have to keep pulling the quarts out and looking at the back of them till you get however many German made you need. Every AZ carries them.
Old 01-26-2005, 09:34 AM
Redlinez's Avatar
The AZ I went to here in Raleigh didn't have it. I'll check at others. How much is it?
Old 01-26-2005, 10:21 AM
Cahill93Z28's Avatar
im using Mobil 1 10w-30 right now but will be changing to 5W-30 in the spring
Old 01-26-2005, 10:22 AM
Neumonic2002's Avatar
Royal Purple here..5W 30
