Ring & Pinion install guide?
Old 01-26-2005, 09:12 AM
Droptopws6's Avatar
Default Ring & Pinion install guide?
Anyone know where I can get one? I have a set of motive 3:73's and just cant get myself to pay 250.00 for the install. I do all my own engine work eg. cam,springs whatever, just dont have the nuts to try ring and pinion. I understand backlash and how to check it but pinion depth is a concern of mine. Is the bearing pressed on the pinion gear? Please PM me if you have an install guide or post advice here. Tried search by the way.
Old 01-26-2005, 11:07 AM
Droptopws6's Avatar
Cant let this post die already.ttt
Old 01-27-2005, 07:49 AM
Richiec77's Avatar
Hold on. I had found one in the past on Richmonds site. Doing engine work is different than setting up a rear. Not hard with practice, but you should find some to help you with it. I'll find something for you or I could kind of walk you through it.
Old 01-27-2005, 08:04 AM
Richiec77's Avatar
Here you go. You need Adobe Acrobat to view it, but Richmond has a link to download it for free.
http://www.richmondgear.com/installmanuals.htm
A few Tips and Tricks I can give you is:
1.) Have access to an Impact Gun. You will definetly need this to get the pinion nut off and to put it back on.
2.) When installing the gears get a new bearing set. Pre-Load on the pinion is around 25 in/lbs new or 15 in/lbs old
3.) Learn to read the gear patterns. No matter what the specs are, the pattern is the end-all on the correct set-up.
Look for a patter that is centered on the Ring teeth.
4.) The new crush sleeve is a BITCH to compress. That is why you will want the impact gun.
5.) You will have to prees the new or old bearings into place. Don't try to hammer them. The bearing will become damaged.
6.) A trick to get you started is to use the Pinion shim for your rear from the factory. I was told that the shim is made for the Housing and can get you very close if not dead on from a get go.
7.) You could have an old pinion bearing shved on the inside that will just slip on over the pinion. This will help you set-up the Pinion depth easier, and with a correct pattern will eliminate the Pinion Depth tool.
You'll need a Dial Indicator to determin Backlash (0.08-0.12 usually, but follow manufatures specs), A Micrometer or Dial Caliper to measure shims, about 2-3 qts of lube, 1 bottle posi fluid.
I have to get to work here soon. I'll get more info to you after work.
Old 01-27-2005, 10:05 AM
14 Second Truck Club
mzoomora's Avatar
Motive Gear Instructions
Get a good impact gun! It helps to get the crush sleeve started in a press, just compress it half way between the thickness of the old one and the new one. Or, save some headaches and get a solid spacer, which is better anyway. Also, I dont know if anybody mentioned it, but if you are going to have to try a few different shims it doesnt hurt to have some dummy bearings. Just take an old bearing and bore the center so it slips on and off.
Old 01-27-2005, 12:42 PM
Richiec77's Avatar
I've read about these solid spacers. I now have an 8.8 and curious where to get one for it.
Old 01-27-2005, 01:45 PM
mzoomora's Avatar
The 8.8 uses the same one as a 9" ford, any good drivetrain/gear supplier will have it.
Old 01-27-2005, 06:40 PM
Richiec77's Avatar
Sweet thanks for the info.
Old 01-28-2005, 09:08 AM
Droptopws6's Avatar
Thanks to both of you for info.
Quick Reply: Ring & Pinion install guide?
