high compression?
high compression?
what's the highest compression you can run pump gas(93 octane) with? what's the best way of goin bout gettin more compression milled heads and flat top pistons, or unmilled heads and domed pistons or any other ideas?
thanks
thanks
looked up diamonds catalog and with 62cc ls6 heads and there off the shelf dome piston it's 12.2:1 ... anyone know what it'll be with 5.3 heads? ... and is 12.2 pump gas friendly
lookin for the absolute most compression possible and still be on pump gas ... someone's got to have tried this before
If you run a coating on the chamber you can run more compression. I run 11.5 to one i think. I could add a full point i think because of the coating i run.I use sunnoco 94 though.
