secret trick for holding the crank in an a4
my mechanic told me a trick for holding any crank to get te pulley bolt off
take a rope and put it in the sparkplg hole and rotate the crank till it stops the rope will hold it ti you are done then just pull the rope out and their is no damage
so there you go
so there you go
I use the LS1 specific Kent-Moore tool that bolts in place of the starter and positively locks the flyhweel. It's so much easier than sticking a screwdriver or whatever into the flywheel.
ps:: I install a new seal any time I remove a pulley($10.00 and 10 minutes now is better than haveing a leak and haveing to remve pulley again
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS: THE DRAWING DOES NOT SHOW UP CORRECT ,it should be about 2 in wide all the way down
Originally Posted by code4
I sell these for $40.00 + shipping & you don't have to remove the starter. (I have permission to sell these here)
I bought this with the puller. I must say it's a nice piece for the $ and should work out nicely. I have yet to try it out (still waiting on my ASP pulley) but it should get the job done nicely.
Originally Posted by Bill Bowling
Will it work with a SLP Pulley?
Bill
Bill
Shane
I honestly don't know, I would think the bolt pattern would be the same as the asp pulley. I need someone to measure the bolt pattern with some calipers on the SLP.
Shane
Shane
Bill
I can't find the Kent Moore / Snap-On tool for the life of me.
I ended up using a 10" long, 2" wide by 1/8" thick plate of steel, wedged up the access port in the bellhousing. I didn't think it would but it actually holds very securely.
I use the rope trick in my two stroke engines quite often. No harm at all.
I bought one of these from you but it will not work on the SLP pulley. The hole pattern is different. It looks like there is not enough metal to drill the pattern. I knew I should of gotten an ASP pulley.
Bill
Bill
Shane
Originally Posted by slow98Z
where can i get one
www.spxkentmoore.com
I got one, looks like it will work pretty good. DrkPhx told me about it, he can probably tell you more than me. I'll be using it soon though.
