Oil Pressure at idle help! (w/pic)
this is the lowest it has ever been in the car.. normally is it right at 40 or just a teeny bit under it... is this a bad sign that the oil pump it about to die? I am within 400 miles or so of the next oil change ( every 3k) would it just be worn out oil?
The car has about 84k on it
Thanks!
Originally Posted by badpewter-z
doesnt look serious to me as long as its not down to 10 lbs you should be fine.
does it go up with rpm?
yes.. it moves around like it should while driving, etc.. I just never noticed it this low before.. if it starts to worsten what should I be looknig for to fix it? oil pump?
LS1TECH Sponsor
hmm.. so bottom end really or the pump... it is does get worse I'll see what I can do.. I would guess a 6.0 block would be not a bad upgrade with a decent cam if I had to replace it
