Racetronix pump installed
Since I already had the rear out I bit the bullet and decided to drop the tank to install the Racetronix plug n play pump. The installation of the pump was the easy part, but getting the tank in and out was a ****. Hooked everything up and the fuel gushes out now compared to the stock pump.
Originally Posted by jrp
i did my install a few weeks ago and getting the tank in and out was a ******* bitch. @ the metal fuel neck . did you drop your rear end?
lol
Was it a PITA because you still had gas in the tank maybe? I'd drive the car untill its almost empty before I'd bother to drop the thing! 1 gallon = 7lbs or something like that.
i just ordered the racetronix pump for my 2002 earlier this week hope to get it soon because i will ahve the rear out for a 12 bolt swap
all i know is that the 98 pump cant be nearly as bad as doing the pump on my 89
i took the panhard bar off and unbolted the shocks and moved the exhaust and it was still a bitch
