noise with moser only on accell????
from 0 to 80 i get this loud howling whining noise..wheni push the gas..wheni let go it goes away????
i have the lpe drive shaft with proper u joint(448)
whats going on...its not really a whining noise...more like a howl...the drive shaft fits... its tight but iti fits...also i have the 1350 yoke as well..if that makes a defference....
let me know...im not sure if i need a different drive shaft..or if something is set up wrong
thanks alot!
thanks alot!
That's what she said...
you can either a) get used to it, get louder exhaust, or turn up the radio
or b) buy a new gearset and have them setup by a reputable rear-end shop. this can fix the problem (usually does fix or at least reduce the noise), or it can not do a damn thing. its a hit or miss kinda thing. my moser 12 w/ 4.11's dont make a sound (havent really launched hard yet).
thanks alot!
thanks alot!
How much slip yoke is showing out of your trans when the car is on the ground(not jacked up with the rear tires hanging)?
Last - did you buy a stock length shaft?
Usually from the backlash not be set properly. If I recall correctly too tight = noise when you accel, & too loose = noise when you decle....or vice versa, I can't remember for sure, it's been too long. But a good rear end shop knows. My 9" is quiet!
But then some OEM gears are just noisy.
