which hose to pull top end cleaner through??
im putting some top end cleaner thru my motor b4 my h/c swap this week. which hose is recommended to feed the cleaner through?
i see a hose running from the passenger side of the throttle body to the passenger side of the intake manifold. should i pull the intake end of this hose and suck the cleaner in thru that?
Originally Posted by gwj
I use the GM aerosol type, and spray it right down the TB at idle.
With the liquid, do as said above.
