Chips/ECU upgrade 2002 camaro z28 m6
Old 02-25-2005, 11:58 AM
blkhurstz28's Avatar
Default Chips/ECU upgrade 2002 camaro z28 m6
ive been looking around for a chip that i can put in my car, (02 Camaro Z28 M6)and i was wondering about several of them. I know slp makes a power tuning program that you plug into the diagnostic port and so does hypertech, but i was also wondering whether or not there are any chips that stay in the car that would help. Whatever gives me the most horsepower . Also ive been loooking on ebay for camaro stuff and i find a lot of stuff like this - http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll? ViewItem&rd=1&item=7956449741&category=33598
i think that on another discription it said that it tells the computer that the air temperature is always 0.00 degrees, and i was wondering if that would mess up the car...
thanks a lot,
-walton
Old 02-25-2005, 12:42 PM
Moderator
jimmyblue's Avatar
Here's a general guideline - if it's for the LS1 and the
person selling it calls it a "chip"... think cow chip.
You can read and write the entire PCM through the
OBDII port and program the hell out of it. But any
little one-trick gizmo is going to leave a lot on the table,
and work by lying to the computer. What did your mama
tell you about lies?
Old 02-25-2005, 12:55 PM
horist's Avatar
lol... I can't believe people still buy this crap... same results can be had at radio shack ... 50 cents for a bag of these chips aka resistor....
Doubtful you'll see any performance gain also... depends on wher eyou live (outside temperature) ... but whoever came up w/that 20hp number was smoking something illegal at the time
Don't even get me started on the hypercrap heh
Old 02-25-2005, 01:10 PM
so id take it that you guys suggest not buying any of that stuff?
lol
then maybeyou can help me out on what i can do, for cheap, with hp gains, and things that are only visible to the trained eye...dad says not allowed to 'modify' the car...as far as he knows im not!
Old 02-25-2005, 01:16 PM
horist's Avatar
filter, air lid, Cold air (such as Fast Toys Ram Air), hidden dry nitrous kit , underpulley , gears, Suspension (you can have all the power in the world but if you can't plant it doesn't matter)
Vinci Performance has a nice handheld tuner, not sure on improvements w/a stock car though...
HP Tuners is an integrated scanner and PCM Tuner and is a very nice stand alone tuning package, but probably overkill for what you have planned at this time
M6 or A4? if A4 a mail order basic tune may help ... increase line pressure, up shifts a little...
You'll want to get bolt on items first, then worry about hte PCM though
Old 02-25-2005, 01:37 PM
ive got a hurst 6-speed, but i dont want nitrous...im scared of it, theres a guy at myschool who drives an 04 M3 with nitrous and its destroying his car...
Old 03-01-2005, 11:45 PM
mrr23's Avatar
when i track tested my 00 formula with the vinci tuner, all i had at the time was a slp airlid. i went from 13.63 to 13.43 on back to back runs at bradenton raceway. i used the hiperf/ stock cam and +10% timing.
just recently tuned the wife's car with it after installing the vinci ported 4.8L heads still with stock cam. i picked up 17/17 on the dyno. here's the graph:
Old 03-03-2005, 08:27 PM
redhotz28's Avatar
what are the other options that this programmer can do. looking at getting one but want to know if lt can do what i want. like adjust for a hight stall adjust fuel curve,ect. let me know thanks.
Old 03-03-2005, 08:28 PM
mrr23's Avatar
here's exactly what it can do. http://www.stealthram.com/vhptuner.htm
Quick Reply: Chips/ECU upgrade 2002 camaro z28 m6
