918 springs
Old 02-26-2005, 11:40 PM
ssheets's Avatar
Default 918 springs
How capable are the Comp Cams 918 beehives?
Are they good enough to handle a 230/236 .590/.598 cam?
I'm thinking they're not quite enough spring, but I'd like to know what the experts think.
Old 02-26-2005, 11:53 PM
Tech's Avatar
Yep. Many folks run them past .600 lift.
Old 02-26-2005, 11:56 PM
ssheets's Avatar
Really, Should I worry about high revs? I'm thinking of bumping the rev limiter to 6500.
Old 02-27-2005, 12:14 AM
That's what she said...
TheBlurLS1's Avatar
if you want peace of mind, throw in a set of duals w/ Ti retainers. you can pick up a set of PRC's or PP duals with springs/seats/titanium retainers/seals for around 280$.... but i do believe in overkill
with that limiter, and that cam, i wouldnt put anything even questionably in-capable in there, its just too cheap for some sho-nuff springs.
Old 02-27-2005, 12:31 AM
Cal
Cal's Avatar
918's are plenty for your cam and rev limit. My 918's are working very well for my 235/240 .602/.598 cam, and I have the rev limit at 6750 rpm.
Old 02-27-2005, 02:19 AM
TheBlurLS1's Avatar
WOW! i guess i've been underestimating those badboys! i've been researching hardcore for a new valvetrain setup for the past week or so. i have a lifter thats speaking a little too loud for comfort and i'm going to change out the whole valvetrain (doing a cam this summer). i'm eyeballing the PRC dual kit myself.
Old 02-27-2005, 02:58 AM
Nate_Taufer's Avatar
The 918's are waaaaaaaaaaayyyyyy more spring than you can imagine. Coil bind isn't until .750 or so, and i wouldn't worry about high ramp rates. The 918s are a very very nice spring for the money and can handle most cams on the market today. The only reason i went to a dual spring is for peace of mind and not worrying about broke valvesprings at 7300 rpms.
Nate
Old 02-27-2005, 04:37 AM
auto_gto's Avatar
what if i had a 238/240 595/598 lift cam and my engine runs till 7200 rpm would 918s take it or would it be risky?
Old 02-27-2005, 08:37 AM
PREDATOR-Z's Avatar
They would take it, but will the rest of your motor? Also at those rpms i would choose adjustable rockers for 100% proper install.
Old 02-27-2005, 03:50 PM
1badV6's Avatar
My friend uses Comps 918s w/ a .605 lift and has had no problems with them. You should be alright with that size lift!!
Old 02-27-2005, 06:46 PM
11 Second Truck Club
LS1BirdDRG's Avatar
I have no prob's w/ 918's on a TR224 on the Formula. Had them for about 10k miles and no issues at all. I would put them on the Z06 with a bigger cam with no 2nd thoughts as well!
