N20 with the yank PT4400?
Old 02-27-2005, 10:56 PM
7 Second Club
ty_ty13's Avatar
Default N20 with the yank PT4400?
well my options have changed and now im looking into the fm9 cam (232"/236" .585"/.600" 114LSA ) with a direct port of about 150-200 shot... will this converter still work or do i need to go a head and send it back and exchange it?
Tyler
Old 02-27-2005, 11:16 PM
White Fire's Avatar
Can it work? Sure it can. But I believe it's by far not the best converter for that application. I think the PT4400 is an N/A converter if I'm not mistaken.
Old 02-27-2005, 11:28 PM
artic-z28's Avatar
spraying on the converter would be nuts..
Old 02-28-2005, 02:53 AM
7 Second Club
ty_ty13's Avatar
right i had other plans for the longest time to go N/A but my plans have changed... just wanted to make sure I didn't need this converter for spraying. so i guess it'll be the yank SS4000e?
Old 02-28-2005, 11:12 AM
Ragtop 99's Avatar
If you're serious about the 200 shot, get a converter to match it.
Old 03-06-2005, 08:47 PM
Old Drag Racer
Smokinstorm's Avatar
I've got the PT4000 and Yank told me that my converter was going to get really loose really fast if I sprayed the car. They also told me shift extensions of 6400 RPM+ on my PT4000 if I sprayed it (5600-5800 RPM on the motor). I cannot imagine what a PT4400 would be. They also told me that the PT series really wasn't the best for N20. If you spray that converter, I hope you've got a really solid valvetrain.
Old 03-07-2005, 01:00 AM
LS1_PNYTAMR's Avatar
well im lost on what these guys do that run unstreetable cam setups that make no lowend, that spray 200-250 shots. surely there not running a 3200 converter and leaving the line at a measily 3200rpms where there power band is non exsistant, so how do u do both?
Old 03-10-2005, 08:22 PM
FACE's Avatar
If you want big stall and to spray, get a SS3800E, etc.. They have a low shift extension and high STR. It'll be perfect for spraying and will also get you out of the hole nicely.
