New Front Suspension Pics>
Here are a few pics of our bolt-in strut kit using a Strange GT Strut. This strut is easily adjusted at the top through a hole in the shock tower. The kit includes our custom mounting plates, lower a-arms, bump steer kit, struts, and choice of brake kits. This brake kit is the lightweight single piston setup that uses a spindle mount wheel. The optional 4 piston kit is recommended for most applications. This is a drag-only setup as it is far too lightweight for street use. All together, this system will eliminate about 100lb from a stock car. Email for more info and pricing.
Thanks
Thanks
Looks good. I was gonna go that route when I did my custom setup but I wanted to stay stock suspension in the front cause of 10.5 races require that. Getting rid of the upper A-Arm like the AJE kit would have banned me along with the LS1tech series.
if it wasnt for the limitations in some of the classes id tell you to cancel my order on front shocks and do that sweet setup.
looks great and im sure it only performs better
