My wheel fell off!
Are you running spacers in the rear? I would say you overtightened them but you already checked that. I would however take the other side tire off and check the studs for any stress cracks. It will be interesting to see what caused this. Good thing it happed when it did and not on launch or worse, at 1/2 track.... could've been real ugly.
Was gonna get w/you after they pulled it back out of the box, but figured I'd give you yer space.
Not fun is it? I did mine on launch though. We are very lucky it happened when ours did!
That's cool, it wasn't a huge deal since nothing got hurt really. I made three runs coming off the transbrake before that last burnout so they could have been getting slammed around every pass and just finally let go. Everything worked out, I ended up just pulling both axles, and took two from the good axle to put in the broken side to get it onto my trailer. I did have to cut them down shorter to get them out though, with the extended studs and the backing plates I didn't have enough room to get them out. Those studs suck to cut with a hack saw! I'm going to upgrade them to a screw in type used on prostock cars, they are about twice the size of the ones I had, I figure if I have to fix it anyway I might as well upgrade as far as I can.
I Check after every pass.
And spacers are bad news.
Sorry to hear your wheel came off. Did it damadge the car at all?
Brad
I think the compressor tightens them much more than the 4 way. Two months ago, me and a neighbor had a HELL of a time taking the wheels off after the tire shop mounted them.
