A4 spraying through shifts...
Old 03-02-2005, 10:44 PM
Michael Ozorowsky's Avatar
Default A4 spraying through shifts...
Is spraying through shifts safe? Just checking if window switch is NECESSARY. Thanks.
Old 03-02-2005, 10:57 PM
Restricted User
CAT3's Avatar
Do a search. This is one of those highly debated topics.
Bottom Line- I dont think its safe for parts, IMHO, it has to cause premature wear. But I spray from the line to the other end. I wasted the stock trans after 600+ passes, loads of nitrous, and ALWAYS Sprayed through the shifts.
Old 03-04-2005, 11:35 PM
mrr23's Avatar
i spray through the shifts on both cars. no issues yet. but, i've done in on all of my cars that have had nitrous on them. it's up to you though.
Old 03-05-2005, 07:22 AM
GM Muscle's Avatar
As said above, highly debated issue. Mine didn't fair so well spraying through. Even if you plan to spray through it is a good idea to have a window switch just in case you hit the rev limiter.
Old 03-05-2005, 08:09 AM
TRYTHSS's Avatar
I also spray from one end to the other. only for 3 passes i hit the rev limiter on 2-3 shift, i adjusted revlimit and the shift points and i was back ready to go. Luckily it has been 2 years with me spraying this car, and no big problems yet.
Old 03-05-2005, 08:30 AM
Dano 00TA's Avatar
I lost my trans spraying through the shifts also. I wouldn't recommend it myself.
Old 03-06-2005, 12:20 AM
Robert56's Avatar
I sprayed my '97 C5 through shifts moocho times, no problems and no window switch. I would recomend adjustments to shift points/rev limit to your needs.
Old 03-06-2005, 05:19 AM
35th SS's Avatar
it will eventually takes it toll on your tranny.blew my 3-4 clutches on my stock tranny on a 150 shot wet.now I have upgraded parts inside.still spraying through the shifts but not as much.
Old 03-06-2005, 07:31 AM
koolrayz's Avatar
I always sprayed through the shifts with no problems. BUT I had rossler rebuld the stock trans with only 11,000 miles. The trans was in great shape but i new it would take a **** when i broke into the 10's. I wont be spraying through the shifts this year with the new motor and a 300 shot it will be more than it can take IMHO.
Old 03-06-2005, 10:07 AM
Tiger2o69's Avatar
I have been spraying through the shifts but I ordered a window switch for safety and its a dial control so I plan to only spray through the shifts when I know I will need it...
Old 03-06-2005, 12:16 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
You're at 345 now and could spray a stock longblock to maybe 450rwhp. Sprayed or not, there's a lot of A4s out there with 450 to 500 hp making many full power runs.
Old 03-06-2005, 08:08 PM
Deckhand's Avatar
Dont you guys think by deactivating, and activating through shifts that the tranny will get hurt by the multiple shocks of on/off from the spray... versus just keeping the same load throughout the entire run?
Old 03-08-2005, 06:01 AM
scalemaster's Avatar
I do spray from the line and don't stop till u get to the other side
this stop and go spaying I don't like
Old 03-08-2005, 06:51 PM
11 & 7 Second Clubs
Keep it constant.
Old 03-10-2005, 08:24 PM
So spray all the way huh? Scary. I have a built A4 with corvette servos, and kevlar clutches, and stuff. Just hope that spraying all through won't hurt anything.
Old 03-10-2005, 08:47 PM
BADBOYZ28's Avatar
I also sprayed from start to finish through my gears on my stock A4 with about 100k until it finally gave out after about 1yr or so of spraying. Like they said its a debatable subject. Every car is diffrent and will handle the spraying diffrent also. But it does cause premature wear & tear. IMO!!
Old 03-10-2005, 09:48 PM
So it causes MORE wear than spray, stop, spray, stop?
Old 03-10-2005, 11:24 PM
12 Second Truck Club
Magic Chicken's Avatar
I agree with the highly debated thing. My name is Eric, and I spray through my shifts. Bottom line, whether you spray through or spray-stop-spray, you will lose your tranny eventually (and everything else for that matter). More power = more wear. Think of the boosted vehicles, they can't turn the boost off for a shift, why should you?
Window switch is just good safety, not made entirely to turn off the nitrous for a shift. Used so you don't spray too low or too high (RPM's).
Old 03-11-2005, 09:16 AM
So would a WOT switch work fine instead of a window switch? Or do you need both?
Old 03-11-2005, 09:25 AM
both, still need something to actually activate the nitrous. unless you do the fast and the furious push button style.
