high idle
Old 03-15-2005, 02:04 PM
obZidian's Avatar
Default high idle
hey guys, i just finished tapping my brothers car, a 2001 ta, with h/c, and this is wat i saw:
current idle:1050-1175
temp: 180ish
tps: .0-.3
Iac: 188-190
set idle: 950
its an automatic car and it idles high. Sometimes on start up it will search for a idle around 600-1000 but go up to 1150-1200 on the tach.
me and my brother with the autotap are new to this so bare with us. Wat do ya'll think?
Old 03-15-2005, 05:35 PM
obZidian's Avatar
from wat ive seen, is the iac to high for idle? If so, if i adjust the idle screw or drill the tb, this will loer the iac counts right? wat kind of porblems do anyone of you guys see?
thanks
Old 03-16-2005, 12:39 AM
obZidian's Avatar
no one?
Old 03-16-2005, 03:15 AM
prostock_bigblock's Avatar
I not prety sure but drilling will raise the idle more (which u dont want to)
Old 03-16-2005, 04:10 AM
TNormZ28's Avatar
Don't drill the TB. Does it stay with a high idle after it's been warmed up? Is it tuned for the H/C?
Old 03-16-2005, 12:15 PM
obZidian's Avatar
yes, its tuned for a h/c and yes, it says up when warm. We are having a hars time with this hand it seems like its not our week.
i dont want to drill the tb but i dont how i could check the sensors to se if they are bad.
could it be a o2 sensor? tps, iac? im stumped guys.........
Old 03-16-2005, 12:25 PM
CATDIESEL's Avatar
can you see desired idle on auto tap? is it lower than actual idle. possibly a vacuum leak (TB gasket, egr prob, intake gasket, pcv hose or valve
Old 03-16-2005, 07:30 PM
Ragtop 99's Avatar
Unusual. Normally iac drops to zero when you are getting too much air. Here it appears that the computer is adding air via the IAC.
Old 03-17-2005, 12:57 AM
obZidian's Avatar
exactly, the engine feels like its running rich but the pcm is compensating and running the idle high enough so it would stay on. Also, you have to give some gas for it to turn over and when we disconnected the TPS, is ran a bit better and didnt have to give gas to start.
any sense?
Old 03-17-2005, 12:59 AM
obZidian's Avatar
yes, desired idle is at 950......
we did look over the seals but ere gonna check again....is there a gauge tool that can help me do this without checking every line?
I think there is? i just remember wat its called...
Old 03-17-2005, 08:35 AM
Ragtop 99's Avatar
Have you done anything to or messed with the PCV or valve cover breather lines?
Old 03-17-2005, 09:38 AM
obZidian's Avatar
he replaced his valve covers and before, the pcv hoses that join together in the back weretorn apart, behind the manifold. It looked like heat destroyed the hoses back there.....
besides that, this could very well be a stupid vacuum leak and we're just chasing our own tails.....
now the actually, pvc valve, i havent gone near it bt how wold i know if its gone bad?
Old 03-17-2005, 10:00 AM
Ragtop 99's Avatar
I had a high idle problem caused in part by air coming through the PCV line into the intake manifold. I discovered it by crimping the line and seeing my idle drop.
Old 03-17-2005, 01:34 PM
obZidian's Avatar
im gonna try that.....
i never thought about that. how much did you crip to make it work? did you use on of those metal o rings with the screw to decrease the size... (dude, im not sure wat its called..sorry!!!)
Old 03-17-2005, 08:52 PM
dissonance's Avatar
Log the strims and ltrims... with the car warmed up give it a rev to 2k and then let off the gas
If the ltrims jump up to like 10 -15+% then you might have a vacuum leak.
I have messed with my idle a lot and if the blade is close all the way and you had 100+ iac steps your idle should be right “the iac would have full control over your idle” but 100+ steps are not good.
I would also try to use the set screw and open the blade a little more… iac steps should go down and idle should stay the same until you open the blade to the point it no longer needs the iac to keep the idle. If you do get to this point close it a little more “ until your steps are around 30-40 in park.
I have found mine idles best at 40 iac in park and that puts me at about 15 to 10 iac steps in drive.
Old 03-17-2005, 10:44 PM
obZidian's Avatar
hey, thanks alot guys.....gonna try allof this stuff in the morning, will let you all knwo how it all went....
i appreciate it, thanks....
