Car has vibration at idle
Old 03-17-2005, 10:23 AM
shouldaboughttheZ's Avatar
Default Car has vibration at idle
My car has a vibration like a miss at idle. I get NO SES light at all, so I figured it has to be something minor. Car has 65k on it.
I have done the following to try and correct it:
Spark plug swap (factory to NGK-TR55's gapped to .055)
Spark plug wire swap (factory to Taylor 409 10.4mm)
Fuel filter (factory to WIX)
Cleaned throttle body and MAF out
I was going to change out the PCV valve, but the one at O'Reilly looks to be a different one (for 98-99 models).
Any other suggestions? Mods are in sig. Going to replace K&N with paper filter.
Old 03-17-2005, 10:56 AM
PREDATOR-Z's Avatar
I've read that Taylor wires had issues, but I have no first hand experience with them. I use MSD
Old 03-17-2005, 11:04 AM
I have not heard about any issues on them. But this problem was there before the Taylors got installed.
Old 03-17-2005, 11:07 AM
PREDATOR-Z's Avatar
Scan it to determine which cylinders. and go from there.
Old 03-17-2005, 11:09 AM
I don't have a scanner and get no ses light.
Just take it down to Autozone and have them scan it?
Old 03-17-2005, 11:11 AM
PREDATOR-Z's Avatar
SES comes on in case of multiple missfires. If only one cylinder does it it won't SES.
If the have an oscilloscope scan yes.
OR FYI, there is a new tool on the market (PRO SCAN).......> sponsor.
Old 03-17-2005, 11:44 AM
checked out Pro Scans website and it looks pretty good. Will have to try and talk the wife into letting me get this.
Old 03-17-2005, 02:11 PM
WS6snake-eater's Avatar
What part of Houston are you in? If you are close I might be able to take a look at it.
Old 03-17-2005, 09:08 PM
I am in the NW Houston. 290 and Beltway 8
I got it fixed. Ended up being a $2 PCV valve. Car runs really smooth now.
Old 03-21-2005, 01:49 PM
Now the damn thing is back. What the hell is going on? I was going to get the scanner as mentioned above but have not been able to yet.
Old 03-24-2005, 01:44 PM
UnleashedBeast's Avatar
I think mine does the same thing, let me know what you find out so I can make sure that's not my problem.
Old 04-14-2005, 01:31 PM
Did you discover your problem yet. I have the same problem and I am trying to fix it. Let me know what you find out so that I can see if it helps me.
Old 04-15-2005, 08:18 AM
I took it to my older brother who is a mechanic and he scanned it with a Genisys scanner. It showed multiple misfires at idle, and some during throttle loads. I had no SES light. He was almost stumped.
Then he decided to do a relearn on the crank position sensor. It would not do it. So he did an osilloscope on the sensor and found it did not have consistant readings. It would have a long them some short ones and doing this randomly. There for the computer was trying to adjust everything it was recieveing from the sensor.
I am getting a new sensor this weekend.
Old 04-15-2005, 04:34 PM
jyeager's Avatar
Well, the CPS might actually be right and you could have a bad timing chain. Doesn't the service manual specify a test procedure for the CPS? Or how about validating the timing chain first. You can do it by taking off a valve cover and turning the crank by hand. Watch to see how far you can turn the crank either way before the valves begin to move.
That will be a whole lot easier than swapping the CPS on a whim...isn't it at the back of the block necessitating an engine pull?
Old 04-15-2005, 04:51 PM
oange ss's Avatar
no, its above the starter
Old 04-16-2005, 12:59 PM
We tried to get the CPS to do the relearn procedure, and had no luck. Tried quit a few times. Thats when he said that must be your problem.
Can you specifiy alittle more on the timing chain procedure. I don't have a manual nor can I find one. How far should it go before the valves start to open?
Old 04-16-2005, 06:00 PM
Well, keep us posted b/c I want to check mine to see if that's my problem too.
Old 04-16-2005, 06:38 PM
I will. Couldn't afford the sensor this week. Next week is the "free check" (5 weeks in this month), and am going to order it thursday so I can pick it up on Friday. Will keep you informed.
