Converter help, which one!!!
I have a 02 z28 A4 with 3.42 gears weighing 3600 with a half tank gas and driver. its stock internally but i have all blot on's, I'm not planning on driving it everyday, but incase i do i dont want anything radical. What stall should i go with 3200-3600, I'm leaning toward the 3600. Does anyone know what the stall is rated at on the street and how accurate is it at the track? Sould i spend a little more and go with a Yank or Vig? I think i want to go with a TCI SSF, I plan on putting a F13 cam in it eventualy, rpm power range around 2800-6000... thx in advance
i would go with the vig 3200 because it will drive almost stock until you get on it, also as you add a head and cam setup to it, it will move the stall up to 3600-3800 range which would put you right around where you would want to be IMO.
