GM Truck Turbo Kit Special Spring Pricing
Old 03-21-2005, 03:25 PM
LivernoisMotorsports's Avatar
Default GM Truck Turbo Kit Special Spring Pricing
Spring is almost here so we're running a discount on the Detroit Speedworks 4.8-6.0L Truck Turbo Kit.
Here is a video one of our customers supplied us after installing the kit on his Escalade EXT. The only modification is the turbo kit at 5 lbs. of boost. Everything else down to the exhaust is bone stock.
CLICK HERE
Look at the AWD Torque Steer!
This kit is complete and includes:
  • Polished Garrett Turbo
  • Black Powder Coated Inlet Tubes
  • Black Satin Ceramic Coating on Hot Parts
  • 42 lb Injectors
  • 3 Core Air-to-Air Intercooler
Dual 4 into 1 Tubular Headers w/ 1 5/8" primaries, 1/2" Laser Cut Header Flanges, 2 1/4" Cross Over, 3" Down Pipe, Powder Coated Inlet Tubes, All V-Band Connections, High Quality Silicone hoses w/ Aircraft Grade SS clamps, Tial 38mm Billet Wastegate, and complete detailed instructions.
* Bolt-on Installation; NO SHEETMETAL CUTTING OR WELDING required! Works with factory electronics.
The Battery, A/C, Power Steering, ABS, etc.. remain in the factory locations, so you could put your car back to stock, very easily at any time.
Pricing will be $4,995.00 for the kit. We recommend a shift kit which would add an additional $300 to the cost of the kit.
The turbo is a GT-37 with a custom exhaust housing, however upgrades are available.
We've seen decent gains with the kit on the Escalade at only 5 lbs. Stock it ran 16.8 @ 80 mph and with 24 inch wheels and a lot of heavy stereo equipment it ran 14.2 @ 94 mph.
Below you will find photos of the kit installed on a 2003 Cadillac Escalade
Click here to see the truck in action. Note: This is at 5 lbs. of boost.
Click Here
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
Old 03-21-2005, 03:36 PM
Adkoonerstrator
XLR8NSS's Avatar
You're killing me here Rick. That is an AWESOME price for the kit.
That thing looks so freaking clean. I love it.
Old 03-21-2005, 05:02 PM
V-10 Killer's Avatar
Damn, I don't even have a truck yet, but now I want one just so I can bolt that to it!
Old 03-22-2005, 10:12 AM
It's definitely fun, I drive the black shop truck with the kit on it quite a bit and it's pretty quick for a tank
-Rick
Old 03-22-2005, 03:02 PM
04BlackGmc's Avatar
Thats bad!
Old 03-22-2005, 09:31 PM
Crazy's Avatar
Rick LeBlanc,
[*]Polished Garrett Turbo[*]Black Powder Coated Inlet Tubes[*]Black Satin Ceramic Coating on Hot Parts[*]42 lb Injectors[*]3 Core Air-to-Air Intercooler
-----All of the above is included in the original kit for $4995.99 correct?
-----Would this fit an '04 GMC VHO (LQ9 6.0 HO), engine almost the same as the EXT and Caddy.
-----Do you have any authorized dealer/installers in the Dallas,Tx area?
-----Can you upgrade to a GT-67 turbo? How much extra would it be?
I was seriously looking at getting an STS, but not to sure about the rear mount style.
Thank you for any information,
Caylon
Old 03-23-2005, 07:39 AM
Caylon
Caylon,
You are correct, everything mentioned is included in the kit for $4,995.00. This kit fits any 4.8, 5.3, or 6.0L Sierra, Denali, or Escalade.
The only thing not included with the kit that we do recommend is a shift kit to save the trans. This sells for $300.
We don't have an authorized dealer/installer in Texas, however the installation is straight forward and has pretty good instructions so any performance shop should be able to install the kit for you.
A GT-67 would require a different flange, however for example you could use a GT-40/67 and it would be a about a $500 upgrade.
Thank you for your interest
Regards,
Rick LeBlanc
Old 08-10-2005, 10:24 PM
ajwz28's Avatar
is it easy to connect the turbo kit to the 2500hd exhaust
Old 08-11-2005, 09:23 AM
Full Throttle's Avatar
Rick you guys have something for an 8.1 Surburban?
Mike
Old 08-11-2005, 02:48 PM
Sent you an email! Thanks
Mike, we don't have a turbo kit for the 8.1, but there are some S/C kits out there for them. You can call our sales guys at 313-561-5500 for more info and pricing.
Thank you
-Rick
Old 08-12-2005, 08:55 AM
I have those too. We will likely go with a Kenne Bell it fits our needs well. Just thought a Turbo would be cool and I just wnt to buy a kit.
Thanks,
Mike
Old 08-18-2005, 01:16 PM
medici78's Avatar
Will this kit work on an Escalade with 91 octane pump? That's all we get out here.
Old 08-18-2005, 03:22 PM
medici78: pm sent.
Thank you
Old 08-22-2013, 11:08 PM
Seth pierce's Avatar
What kind of hp can the Turbo produce?
Like can it handle 18-25psi or no?
Old 08-23-2013, 09:31 PM
kevin99hoss's Avatar
Try asking/looking in the forced induction sub forum. Gonna be a better place to look then a 8 year old thread sale special thread
Old 08-23-2013, 11:47 PM
They still make this kit I just want to know how much psi it can handle?
Quick Reply: GM Truck Turbo Kit Special Spring Pricing
