SY3500 lacking?
SY3500 lacking?
ive been testing my SY3500 today. well i need some info from u guys. at around 40-45 mph i stomped it and the tires didnt break loose
i thought for sure that this stall converter would definitely burn em down at that speed. is this normal with the SY3500? i mean i could tell a difference but just thought it would have broke the back end loose?? TIA
so what do you think is making the power to get that MAJOR tire smoke? your filter or cheap exhaust? you dont have the power to do that, stall or not, unless you've got more than is in your sig.
OUCH!!!
Longtube headers should be your next mod.
FWIW, STR is measured at zero rpm on the converter output shaft. The Only time the car sees the full STR is at launch assuming no wheel spin and an ability to brake stall close to actual stall. The torque ratio decreases quickly after launch on most high STR converters. By the time you go through the 1-2 upshift, you'll have 3300+ rpm on the output shaft. At this point, shift extension and blade angle become the biggest factor in generating a positive torque ratio (i.e. torque multiplication).
the SY3500 works great for mantaining traction from a dead start and will pull strong thru the mid range to top end
here is some info for you to look at
you will see the range of performance of the lower STR of 1.63
http://www.converter.cc/tech.htm
were dead even from a roll and at the track I beat his time by a bunch
I ran 12.89 and he ran 13.50 all with stock tires.
It was great fun and the sy was the difference.
John
