Painting headers???
Old 03-23-2005, 08:55 PM
soundengineer's Avatar
Default Painting headers???
Probably buying some Hooker Longtube headers.....
going to buy the uncoated to stay within my mod budget(along with my cam and other goodies )
so I want to know If I can just paint the headers to protect them a little bit more...
any high temp paints really hold up to header heat abuse???
Old 03-23-2005, 09:06 PM
Moderator
jimmyblue's Avatar
I used the "cast iron gray" high temp paint from
POR-15 on my manifolds and it seems to have
held up pretty well. It likes an existing base coat
of rust to bond with. So you might want to strip
the original black and leave them outside to get
a little oxide film going.
Old 03-23-2005, 09:26 PM
why would I want a "rust Film" to form......
thats just asking for trouble....
Rust is always bad
But I do know how to scuff things up to get the paint to stick...I just didnt know if anybody made a paint that was really going to hold up
Old 03-23-2005, 09:32 PM
w02ramair's Avatar
Is there any type of Poweder Coating that could be done?
Old 03-23-2005, 09:34 PM
I dont really have the budget for the powder coating...and I really dont have the oven size for it either....
Old 03-23-2005, 09:42 PM
Bad Seller Warning!
SoSlow's Avatar
I used rustoleum high temp flat black,it has held up well for a couple of months now.
Old 03-23-2005, 09:45 PM
Grimes's Avatar
i'd scuff up the paint that's there, or strip it, then hit the headers with brake cleaner to get off any residue.
Old 03-23-2005, 09:48 PM
Brett95z's Avatar
Id just use some engine paint.
Old 03-23-2005, 09:56 PM
Tritonium's Avatar
http://www.jet-hot.com/
these coatings are awesome!!!
I highly reccomend them. It will cost a bit extra, but it's well worth it.Your headers will be close to bullet proof.
Old 03-23-2005, 10:25 PM
99Blk Z28's Avatar
Rust is always bad
The reason he said to let some rust form is cause Por-15 tends to stick better to rust then it being clean. Its made for restoring cars and other things that rust. Seems like the best thing to me for the kind of price ur looking for.
Old 03-23-2005, 10:32 PM
so that stuff is made to be a rust cover up???
still...isnt rust..even though covered up..still rust???
isnt that a bad thing???
Old 03-23-2005, 10:34 PM
6 Second Club Moderator
LASTLS1's Avatar
Ace hardware $5.00 Weber Grill paint works GREAT!
Old 03-24-2005, 12:53 AM
smoknta's Avatar
I used some VHT 1500 degree paint. I did sand blast them first. It lasted the entire time they were on the car. Pretty good stuff.
Old 03-24-2005, 08:52 AM
Strokinit383's Avatar
You would really have to use it to understand. It neutralizes the rust so that it will never spread. It dries into one of the hardest surfaces you can imagine. Its really amazing stuff, works wonders when restoring cars. Expensive though.
Old 03-24-2005, 08:59 AM
GuitsBoy's Avatar
POR-15 does indeed nutralize the rust so it dosnt spread. You dont need alot of rust, just light surface rust. The coating uses the uneven oxidized surface as a tooth to adhere to. Like he said, strip the headers and leave them outside for a little while just until the color starts to change and look rusty. You dont need big chunks and flakes of rust peeling off the headers.
Also, I sprayed VHT 1500 clear over my already coated jet-hot headers and it seems to be helping quite a bit.
