new engine with low oil pressure swaped oil pumps still happening
we just rebulit the engine and used a ported oil pump and when we fired it up we had 5-15 lbs of pressure, so we replace the sending unit same thing, so we replaced the oil pump again and used a new seal still same thing. what are we missing
You using a stock timing set? Was this a new block? Was the block at a maching shop? Was the plastic oil "plug" in the pass rear of the block in before you put the rear cover on?
You didn't check clearance on any of the bearings before final assembly. If the plug in the back is not in you should have zero oil pressure. Does the pressure increase at all with rpm? Did you pack the oil pump with any grease before installing it?
What was the measured clearance for each main and rod bearing? Using all new stuff is fine, but you'd still want to measure before final assembly.
Also, what did you torque the mains and rod caps to?
Originally Posted by L P C
new stock crank and bearings, replaced oring with pump and made sure it wasnt pinched
are you going by the oil gauge in the car or did you check the pressure with an external gauge?
a ported oil pump will sometimes cause a lower idle oil pressure, remember a bigger opening will allow more oil flow but less oil pressure at idle
yes we used the spacer on the oil pump and we are going by the guage in the car, also the friend that brought it to me says that the oil pressure dropped like this before he lost the #1 bearing , could it be something in the oil passge way and how do i check for this
Since you're not answering the bearing clearance questions, I'm guessing you didn't measure them.
A blockage downstream of the pressure sensor would actually increase indicated pressure, right up until the engine let go. As for a blockage upstream of the sensor, there's just the oil pickup tube, the pump, the filter, and the block castings between them.
I'd pull the oil filter and cut it open, inspect the filter pleats for metal flakes. They make specialized cutters, but you can punch a hole in the cannister and use snips or side-cutters to open it up.
Pathological Modifier
There are four possiblities:
1. Air being sucked into the oil pump due to a bad o-ring
2. Oil escaping the oiling system prior to reaching the bearings
3. Bearing clearances too large.
4. Oil Bypass in the pump sticking open.
Ryan
You should check your oil pan gasket, if you did not replace it, then odds are it is too crushed in the fliter area and not making a good seal.
When this happens, oil will leak past the gasket and back into the pan.
11 & 7 Second Clubs
