do i need a transgo to go w/ my TCI 3500
Old 03-26-2005, 11:01 PM
seadoo's Avatar
Default do i need a transgo to go w/ my TCI 3500
i have a 2000 T/A, do i need to put in a transgo when i put in the stall converter? i know they put them in the trucks.....
Old 03-26-2005, 11:15 PM
TNormZ28's Avatar
It's not totally necessary, but a good idea and will be of benefit.
Old 03-26-2005, 11:45 PM
SebastianLopezJr's Avatar
I agree, not necessary but might as well do it while you are changing the TC.
Old 03-27-2005, 02:34 PM
Pontiacerator
RevGTO's Avatar
Also agree, it's not necessary. But it's obvious that a 10 inch converter is not going to move fluid like the stocker. The Transgo compensates for this with revised shift valving, larger separator plate passages, and upgraded lock-up valve. The benefits are firm, perceptible shifts, increased fluid circulation, and solid TCC engagement. It is easier to do with the tranny out, so there's no better time than when you're installing the TC.
Old 03-27-2005, 08:16 PM
Retired Street Racer
Matt D's Avatar
i recommend one as well. i put one in mine when i put in my tci ssf 4000.
Old 03-27-2005, 08:20 PM
1 BLOWN V8's Avatar
I also put in a trans-go kit with a 3,200 stall. Dont forget a trans cooler. That I would do without question.
Old 03-27-2005, 09:21 PM
seadoo's Avatar
thanks for the imput, how long am i looking for the install? i mean as in the stall and the transgo...i put in the tranny cooler the other day, took all of about 15 minutes.
Old 03-27-2005, 09:36 PM
1 BLOWN V8's Avatar
To R&R the trans a good 4 hours plus if you are doing it on your back. If you have a lift and power tools a little faster.
Old 03-28-2005, 09:18 PM
seadoo's Avatar
thanks
