Dual stage or single big shot?
Old 03-27-2005, 10:15 PM
ATVracr's Avatar
Default Dual stage or single big shot?
What do you guys think?
hit it with the 200-250
or 150 + 50-100 ?
Gonna try this on 325/50 MT drag radials
By the way I wanna rip the bumper off at least 1 time
Old 03-28-2005, 01:27 PM
383LQ4SS's Avatar
is this a stock short block? Id say dual stages using dual window switches or better yet the new NX/FJO dual stage controller. One stage at 3000 and the other at like 4700.
Old 03-28-2005, 07:56 PM
slow trap's Avatar
i vote dual stage also.you can always pill it up a size or 2 on the second if still not fast enough.short block would probably last longer also.
Old 03-28-2005, 08:02 PM
Robert56's Avatar
If you really want to get that bumper dragging, then go for the big hit out of the hole (nothing like a massive torque spike). But, if you want to save wear and tear, and possibly a better 60ft (traction) go with the dual stage.
Old 03-28-2005, 09:44 PM
Navy David SS's Avatar
I'd say dual - BUT it depends on your set-up - suspension, rear-end, engine mods, fuel, etc.
I have a stock bottom end. I shoot 200 right out of the hole. BUT I have all aftermarket suspension, aftermarket fuel pump, window switches, etc. More than likely it will go to 250 this summer.
Every trip down the track could be the motor's last You spray you'll end up paying soon or later.
David
Old 03-28-2005, 11:56 PM
ATVracr's Avatar
Its got forged pistons and ARP rod bolts in it.
TH400 + Tbrake
90/10 hals up front spoon TQ arm, lca's ...12 bolt
have the bigger intank pump and going to hot wire it.
I'd like to hit it with the 200 shot outta the hole but the DR's might not hook
HMMMM .. maybe through some slicks on it for a few passes then dual stage it
I also put on a K member, lower A arms and took out the front bumper support over the winter ... Wheelie weight
Old 03-29-2005, 12:04 AM
GrannySShifting's Avatar
You know my vote, leave on the 120 to 150 jet, and bring in the extra 100-150 after peak torque. Keep the front end low(er then verticle) and hooking. With the window switch and that time delay thing I found, we can hook enough nitrous to go deep nines on the radials I think. Aint skeerd
Old 03-29-2005, 01:52 AM
red90cobra's Avatar
I'd say leave with as much nitrous as the tires will hold them put a second stage on it after that.
Old 03-29-2005, 01:19 PM
V6 Bird's Avatar
or 150 + 50-100 ?
If the suspension is right you wont have an issue with that tire whatsover...Ive blasted it with rigt at 700 ft lbs of torque off the t-brake and they stuck like glue for me. Blast it with all 250 out the gate!
Mike
Old 03-30-2005, 09:25 AM
Hmmm id rather leave with 200 then add another 150 up top
Old 03-30-2005, 09:32 AM
red90cobra's Avatar
i'd do it in a heart beat
Old 03-30-2005, 10:44 PM
Elite_Hot_Rod's Avatar
I say come out of the hole on both stages, at least a 300 shot, you'll stand it up right on the bumper. lol
Old 03-31-2005, 11:31 PM
ATVracr's Avatar
Old 04-01-2005, 01:30 AM
Eugenio_SS's Avatar
big shot w/ progressive controller.
Old 04-01-2005, 08:44 AM
Messiah's Avatar
If you go the dual stage route I would hit the second stage about a second out of the hole.
Old 04-01-2005, 09:44 AM
I hate progressive controllers, wont use them on that car. Window switch and a time delay makes me a progressive controll
