What are my options now?
Old 03-28-2005, 12:35 AM
ArcticZ28's Avatar
LS1Tech 20 Year Member
Question What are my options now?
Well, one of my heads, all my pistons, and one cylinder wall is/are completely screwed... (refer to this page for the details). So, now the question is, what are my options? Finding another LS1 with low miles and a decent price may be hard to find. Assuming I don't go the new engine route, what options do I have in terms of rebuilding my engine? I want to spend as little as I have to, but I also want to take advantage of any opportunities (such as stroking the engine, etc) that may be available to me. Basically, what would you all do in this situation, keeping in mind that my money was mostly depleted from the cam/intake/tb install.
Old 03-28-2005, 12:12 PM
ArcticZ28's Avatar
OK.... well, I'm leaning towards boring .030 over and re-sleeving with new oversized pistons and rings. I'm just not sure about how much that would run and what displacement I would then be running. Also, what type of pistons would be best for this?
Again... this is assuming I went this route. I'm definitely open to all other suggestions.
Old 03-28-2005, 03:37 PM
66deuce's Avatar
there are several sponsors that offer rebuilt shortblocks,LPE had a special last month(2095.00 plus a core charge)if i was in your shoes that's what i would do.by the time you buy all the parts to do it yourself plus machine work you'll probably come close to that.AP Engineering,MTI,LPE are just some of the sponsors that sell shortblocks.call them up and see what they offer.by the way,sorry about your motor,that sucks .good luck on getting it fixed.
Old 03-28-2005, 04:18 PM
SSU'S Vice Mod
sb427f-car's Avatar
Yet you would definately learn something if you've never rebuilt an engine before and need/want to. Just make sure you go slowly! Paitence is a MUST!
Old 03-28-2005, 05:01 PM
Viper's Avatar
I'm now on my 3rd engine in this car, and after 4 years of research it's just cheaper to buy a shortblock than rebuild your existing one, plus most will take the old one as a core. LPE took mine and it had piston damage; they only care about the block itself. Food for thought.
Old 03-28-2005, 05:18 PM
ArcticZ28's Avatar
Alright, I guess I'll look into just getting a shortblock. Although, one of my heads is screwed, so hopefully I can get a set of those at pretty cheap. Which shortblock would you all recommend? I'm lookin to spend 4k at ABSOLUTE most (I'd like to spend less than or equal to 3k if possible) for everything. Also, I'm really contemplating going with a 383 stroker... anyone have suggestions on where to buy a rotating assembly from? I'd like to go with Eagle b/c of my budget. Thanks guys.
And by the way, LPE's site is down at the moment so I have no idea what their prices are running.
Old 03-28-2005, 06:43 PM
66deuce's Avatar
if you want to call the phone no. is 260-724-2552.talk to ed potter,he posts on here from time to time.or you can PM him thru the board.
Old 03-28-2005, 07:32 PM
Viper's Avatar
"Also, I'm really contemplating going with a 383 stroker... "
Not for 4K.
Shortblock 346 $2100 - $3500 depending on parts picked
Heads $1400-$3000 depending on parts picked
Cam - $400
pushrods - $110
gaskets + fluids, bolts - $600
assembly - $500
starts to add rather quickly.......
Old 03-29-2005, 01:01 AM
ArcticZ28's Avatar
Not for 4K.
Cam - $400
pushrods - $110
assembly - $500
Well, all I need is the rotating assembly. I have the rest and can assemble myself and know a guy that can bore the engine for me.
Old 03-29-2005, 02:11 AM
PREDATOR-Z's Avatar
Much cheaper to get a fully balanced and blueprinted short block.
You can definately get one for less than $3K outright with really good parts in it..
Try LME (sponsor) and talk to Bryan, he is hooking me up with a longblock and parts for parts, his motors are top notch.
Old 03-29-2005, 02:27 AM
T/A-Speedfreak's Avatar
There was a gp a while back and the sponsor had a 383 for $3300-$3500. I don't remember the exact price, so it is possible to hit your target price. They said to crate it was $75.00 and shipping was something like $200. I also saw a shortblock with new crank, pistons, rods, bearings on ebay for $1500 from a machine shop. As for heads, stock heads aren't priced too bad.
Old 03-29-2005, 02:46 AM
Tech's Avatar
APE has 383 shortblocks for under $2500
Old 03-29-2005, 05:15 AM
You can't beat that! That leaves you money for heads as well! Good Luck!
Old 03-29-2005, 05:53 AM
equandt's Avatar
I'd be talking to APE or LPE. Either will get you a very nice product.
Good luck.
Old 03-29-2005, 07:08 AM
crainholio's Avatar
Not to put too fine a point on it, but after what happened from the botched cam swap are you sure you want to be doing engine assembly??
Got a set of micrometers, runout gauge, angle-torque meter, super-accurate torque wrench, etc? Nice super clean room and workbench to keep dust particles from getting into the engine during assembly?
I've built SBCs since 1988 and I wouldn't build an LS1 bottom-end. Much more cost effective to buy a pre-built shortblock from a reputable shop.
Old 03-29-2005, 11:49 AM
ArcticZ28's Avatar
I'll be contacting APE and LME today about a 383. Hopefully they can hook me up with something decent.
Old 03-29-2005, 12:05 PM
Tech's Avatar
Sorry, $2500 is just for the parts. It's not assembled.
Old 03-29-2005, 12:24 PM
ArcticZ28's Avatar
Either way, assembled or not, I'm lookin for a good deal within the 2-3k budget (preferably lower in that range if not assembled). I've also heard that I might just want to go with a 408 if i'm gonna spend the money for the 383 stroker already, since the price difference is minimal. What do you all think?
Old 03-29-2005, 12:32 PM
tim99ws6's Avatar
I have a set of stock heads fully assmebled minus the rocker arms, a set of stock pistons, and a set of stock rods. All you'd need is to hopefully get you're #8 cylinder cleaned up(maybe a dingelbury tool??), or get another stock block. PM me if you are interested in this stuff. the heads are #853 casting by the way.
Edit:Why not just bore the block 10 over, and put some aftermarket pistons in it? I mean, if you're in such a financial bind, what are you doing looking at stroker(382C.I.) motors? Do what you can afford, not what you want. Mahle pistons can be had for $550 with rings, and the maching work isn't that expensive. Is the cylinder completely ruined? How deep are the scratches?
Old 03-29-2005, 12:47 PM
v8maro's Avatar
In mid-may I will be selling my patriot stg 2 heads and a 231/237 cam, comes with springs retainers, valves etc. I am sendnig them back to PP to get cleaned up before I sell them. Let me know if you are interested, it'll be cheap. You are crazy if you even THINK of getting away with a 383 for less than 4k if you want it to perform. Get a 370 from APE and get new heads and cam, it'll be in budget then. A 383+ is going to put you into the 5-10k range, trust me, I know.
