What are my options now?
Again... this is assuming I went this route. I'm definitely open to all other suggestions.
.good luck on getting it fixed.
.good luck on getting it fixed.And by the way, LPE's site is down at the moment so I have no idea what their prices are running.
Not for 4K.
Shortblock 346 $2100 - $3500 depending on parts picked
Heads $1400-$3000 depending on parts picked
Cam - $400
pushrods - $110
gaskets + fluids, bolts - $600
assembly - $500
starts to add rather quickly.......
Not for 4K.
Cam - $400
pushrods - $110
assembly - $500
You can definately get one for less than $3K outright with really good parts in it..
Try LME (sponsor) and talk to Bryan, he is hooking me up with a longblock and parts for parts, his motors are top notch.
Got a set of micrometers, runout gauge, angle-torque meter, super-accurate torque wrench, etc? Nice super clean room and workbench to keep dust particles from getting into the engine during assembly?
I've built SBCs since 1988 and I wouldn't build an LS1 bottom-end. Much more cost effective to buy a pre-built shortblock from a reputable shop.
Edit:Why not just bore the block 10 over, and put some aftermarket pistons in it? I mean, if you're in such a financial bind, what are you doing looking at stroker(382C.I.) motors? Do what you can afford, not what you want. Mahle pistons can be had for $550 with rings, and the maching work isn't that expensive. Is the cylinder completely ruined? How deep are the scratches?
