Drag Racing Tech
How fast on a 16" or 17" radial??
Old 03-31-2005, 11:20 AM
4bangermustang's Avatar
Default How fast on a 16" or 17" radial??
Wondering how fast some of you guys went on a 16" or 17" radial. Don't care which brand, just about the size mainly.
Thinking about running in scandalous's 17" radial class and I want to see how slow in that class I'll be.
If you could include your car's weight and power adder(s) also, that would be great...
So far the fastest I've seen is like 10.70's. and a supra that claimed 9.90's with the stock twins(a little iffy if you ask me).
thanks,
Brian
Old 03-31-2005, 04:26 PM
T6Rocket's Avatar
Er, that's me......I never claimed stock twins, they are HKS 52 trim turbos, plus all the supporting bolt-ons.
It was on the BFG 255/50-16's.
Al
Old 03-31-2005, 04:59 PM
10 second playa
Anonymous's Avatar
Al
What was your 60' and which tires were you using?
Old 03-31-2005, 05:06 PM
Silvr98z28's Avatar
Twin Turbo Viper in new Hot Rod went 8.75 with a 1.36 at 168mph.
QTP 28x12x16. HArd to beat!
Old 04-01-2005, 07:42 AM
T6Rocket's Avatar
1.49 60' on BFG 255/50-16's
The Viper's time doesnt count for this inquiry - QTP means Quick Time Pro Slicks.
Al
Old 04-01-2005, 08:54 AM
10 second playa
Anonymous's Avatar
Al
Wow a 1.49 60' on those tires is pretty good.
How much does the car weigh?
I just figured you were getting the ET from big MPH on the back half.
But good 60'
Old 04-01-2005, 08:58 AM
Silvr98z28's Avatar
Al
QTP's are DOT but I didn't notice thart he was specifically looking for radial till now.
Old 04-04-2005, 03:20 PM
T6Rocket's Avatar
But good 60'
It is 3530# race weight, sometimes more if I need to add ballast to the rear! It is very hard to get a good ET on all MPH, got to have a good 1/8 mile time.
Al
Old 04-04-2005, 03:54 PM
10 second playa
Anonymous's Avatar
Al
You are right but I have seen quite a few turbo car do an OK 1st 1/8th
mile then have a big second 1/8th rush.
So you went 9.90 with a 1.49 60' at 3530 pounds race weight?
Or was that 60' from a different run?
You still have to have big MPH to run in the 9's with a 1.49 60'.
What was the MPH when all was said and done 135 ?
Still a good 60' on 255/50-16 BFG's is that a record? Especially for being at or above 3500 lbs. It is the quickest I have seen.
Old 04-04-2005, 11:31 PM
damn, 9.90's I way out of class.....
I hope only the slow supras show up
Old 04-05-2005, 10:22 AM
NOTFAST's Avatar
what about 17's?
Old 04-05-2005, 11:59 AM
T6Rocket's Avatar
The 1.49 was on the 9.90@139.00 run. The MPH was unusually high on that run, good air I guess.
I usually trap in the 135's - which would have been enough to still get a 9.9X, based on my 2nd best run from another day - 10.13@135.5 with a 1.64 60'.
I just switched to the M/T Radials, hope to get another 1.49!
Al
Old 04-05-2005, 12:27 PM
Formula94's Avatar
On 17" Nittos I ran the times in my sig.
A buddy of mine with a supra was running high 10s at low 13xmph on 17" Nittos also.
Old 04-05-2005, 12:33 PM
gator's 99TA's Avatar
WILWAXU on this board went 10.90s N/A i believe on full street trim with 17" chrome SS rims on drag radials.
a long time ago Colonel went mid 10s i believe on 17" tires N/A 422
Old 04-05-2005, 02:53 PM
NOTFAST's Avatar
im trying to get into the 10's on 17's with stock internals and spray
Old 04-20-2005, 09:32 PM
10 second playa
Anonymous's Avatar
Al
You see, good MPH 139... Are the M/T radials 16" too?
Is that 9.90 on the 16" BFG DR a record at 3500#?
Good luck with the M/T DR, I hear they are great.
Old 04-20-2005, 09:34 PM
10 second playa
Anonymous's Avatar
Years ago I saw Big Daddy in his turbo mustang go 9's with BFG Drag radials size 275/40-17 front and rear. I almost fell over. This was when DR's first came out years and years ago.
Old 04-20-2005, 10:33 PM
LS1LT1's Avatar
Thumbs up
Dwayne is the man when it comes to DRs, isn't he like in the mid-high 7s now, like 2nd quickest on DRs?
Old 04-23-2005, 09:26 PM
10 second playa
Anonymous's Avatar
Yes, he is.
