maf lb/min
Old 04-02-2005, 01:42 AM
luv2spd's Avatar
Default maf lb/min
How many lb/min are you guys getting at wot. The only recent log I have shows about 39.X at 6000 rpm. Is this in range for a cam only car? I know everybody's numbers will prob. be different b/c of scaling the maf or something but I just want a rough idea. If I remember right, my car only did high 20s stock.
Old 04-02-2005, 09:51 AM
RedHardSupra's Avatar
yup, sounds about right, i get 37-40 in 6000-6200rpm range depending on weather
Old 04-03-2005, 12:08 AM
luv2spd's Avatar
ttt, anybody else?
Old 04-03-2005, 12:22 AM
92SilverSHO's Avatar
i get around 30-31 at WOT around 3000rpm, not sure above that, thats when my log ends.
i would like to know whats a normal amount
Old 04-03-2005, 10:23 AM
P Mack's Avatar
Your numbers sound about right. A rough rule of thumb is 10 rwhp per lb/min.
Old 04-03-2005, 10:43 AM
**** then im way off, i get that around 3krpm, and im not making huge HP. but my car is having a 10mpg problem
Old 04-03-2005, 05:24 PM
P Mack's Avatar
Yeah you should only be getting 15-20 there. Do you have an aftermarket maf?
Old 04-03-2005, 07:19 PM
cablebandit's Avatar
67.75 @ 5300...turbos baby!!!!
Old 04-03-2005, 07:40 PM
luv2spd's Avatar
So do you have around 670 rwhp?
Old 04-03-2005, 08:05 PM
Another_User's Avatar
40.76 @ 6026rpms. If I go to the dyno and show 407 rwhp I think I will crap my pants in joy.
Old 05-27-2005, 10:11 AM
gtodoug's Avatar
I'm seeing 44.68@6506 rpms. Are you supposed to see 10whp for every 1lbmin logged?
Old 05-27-2005, 11:04 AM
txhorns281's Avatar
~45
Old 05-27-2005, 12:12 PM
7 Second Club
Phil99vette's Avatar
I'm seeing 46lbs/min @ 6500 and I have 700 more RPMs left/lean A/F.
Phil
Old 05-27-2005, 12:24 PM
yup, i've seen upwards of 50lbs/min on big H/C with 90/90 setups at ~7000rpm
Old 05-27-2005, 01:29 PM
txhorns281's Avatar
it may also depend on how fast you are willing to go, 45 lb/min for me is at like 145 mph...
Sport Side's Avatar
This is a reading of the amount of air passing the mass air flow, correct? So, how do you relate this to power? "If" the rest of the system does its part correctly, you "could" produce this much power?
Old 05-27-2005, 02:01 PM
WS6FirebirdTA00's Avatar
i get about 101.6 so that means i have about 1016 rwhp right? haha jk that would be cool though. ill let u know what i see once i get some log info again after the swap (h/c)
Old 05-28-2005, 03:54 PM
ZDEN's Avatar
i see 34.7 lbs/m on my truck. i doubt its putting down 347 rwhp though. if its fwhp i could believe it.
Old 05-28-2005, 03:57 PM
i see 40+, and i doubt i'm over 350. this is a horrible approximation i think, as you dont' take volumetric efficiency into consideration. i guess if we took a lot of data (from teh same dyno at that!) we could come up with some sort of correlation beweetn airflow and hp ratings.
Quick Reply: maf lb/min
