narrowest tire on a 9" rim
Old 04-04-2005, 01:51 PM
TNormZ28's Avatar
Default narrowest tire on a 9" rim
What is the narrowest tire I can put on a 9" rim without the tire sidewall looking stretched out to the rim? 255? This is for the front.
Old 04-04-2005, 01:54 PM
gator's 99TA's Avatar
why would you do that? rolling resistence is still goign to be high with a 255mm wide tire.
Old 04-04-2005, 02:00 PM
TNormZ28's Avatar
Cheaper tire and it couldn't hurt.
Old 04-04-2005, 02:03 PM
777's Avatar
i'd say 255-265
777's Avatar
i think the vettes run a 265 on a 9.5"
Old 04-04-2005, 02:28 PM
98'MidnightBlueBird''s Avatar
no its 225
Old 04-04-2005, 02:37 PM
777's Avatar
if you run a 225 on a 9" rim you better have AAA
Old 04-04-2005, 06:47 PM
so you are looking to save some money with a ever so slightly narrow tire? just throw on some khumos or other knock offs. it will look like total **** with a 225 on a 9" front wheel as well as being dangerous.
it wont make a lick of difference in rolling resistence or ET.
Old 04-04-2005, 08:39 PM
BLCKBRD's Avatar
I think you can put a 245/45/17 (I assume you have 17's) on a 9" rim, but I don't know for sure.
Here's a chart from tirerack.com
Old 04-04-2005, 08:54 PM
DietCoke's Avatar
I've got 245/45/17 on my 9.5" rims in the front with no problems. They dont look too stretched, either.
Old 04-05-2005, 01:24 AM
TNormZ28's Avatar
I have skinnies for the track. Just wanted a narrower tire for the front on the street. Thought it would help reduce some of the road walk that the wider tire has. No I will not put a 225 on there. Maybe a 255. I had a 245 on a 9.5 inch rim and the tire was stretched too much for my taste. And yes they are 17x9 Zr1 style from SLP.
Old 04-05-2005, 01:28 AM
Eugenio_SS's Avatar
Old 04-05-2005, 01:40 AM
matts22's Avatar
I have thought of doing this too on my stock 9" WS6 wheels. The 275 GSD3's rub in the front and are a lot wider than stock (heavier too), so I was thinking about changing to a 245ish front set of tires (staying with GSD3's). Also, I'm trying to find an answer, but with the heavier tires in the front, it seems like I have lower gas mileage than I had stock. Is this possible? I would think that it makes sense, because the tire is bigger and heavier, so it takes more to turn it. Thoughts?
Old 04-05-2005, 04:34 AM
TNormZ28's Avatar
Thanks for all the input guys.
Quick Reply: narrowest tire on a 9" rim
