must read! stock bolts with qtp headers nightmare
well i broke one of my header bolts off a few weeks ago and my mechanic finally got the bolt out for me. turns out that ALL the stock GM bolts that came on the car with the manifolds were bottoming out when reusing them on the qtp headers. this is not a post against qtp. they make great products. just wanted to let everyone know that my stock bolts bottomed out, i suggest you do not reuse the bolts and go with something shorter. so any guys with little leaks your stock bolts may be bottomed out too. pull the gasket out and see how the metal ring on the gasket is not flattend out the way it should be.
yeah very strange... I reused the stock bolts on my hooker tubes on the old car..and the flange is thinner than on the qtp's....I had no problems.... and you can put the bolts all th eway into the hole with the headers off....
sounds more like you maybe had some cross threading going on...or maybe some gack in the hole or something...
also I know of 2 perople here local kc that swear by stock bolts on all headers....and they do a shitload of header installs.....
it makes me curious about your setup and block....not that its bad...just curious why your bolts had that problem...
Originally Posted by 35thls1ss19
mine worked fine No problem... and you mechainc did chage you brake calipers after only 40k miles If i were you i would get a new machanic
my brakes were beaten to **** and my mechanic gets direct prices from GM so my calipers were 26 bucks. cj go outside and start up your car. hear all those ticks, yea those are exhaust leaks, you just cant hear them too well over the ory and gmmg. my mechanic had made more of a life for himself them you ever will going to county for the amount of years you have
thats is weird.... i have the stock bolts on my QTPs... and i had them also when i had Jethots... no problems here... to me it seems that maybe your car had different bolts to begin with??
Yeah jay, not trying to be a dick here, he is a great mechanic, he fixed my car faster and better than the other hack job....
but there's no way those bolts are bottoming out. How do you know if the ends arent marred form taking them in and out so much? plus those heads are SOFT aluminum, if they were bottoming out, your thread would be shot to ****.
my mechanic doesnt lie. none of you drove my car and none of you saw the defective caliper that was on the front of the car. and thanks for making me realize that i have better things to do then talk to people on these forums. its just a car. jeez. should have never gotten that thing just from the headaches that i get from talking to people like you guys
