polly mounts
not sure
Originally Posted by ssfirefighter
What is there to gain using polly mounts?
if you suffer from a banging y-pipe poly motor mounts can help you solve that issue. they reduce motor flex on the k-member under load...which in turns doens't swing the y-pipe toward the undercarriage.
Originally Posted by 99f1
Thanx for the brilliant input
y pipe
Originally Posted by jrp
i bought mine from TR but my local autozone carries them as well; energy suspension.
i got the poly motor, tranny, and tq arm mounts. lets just say my **** is stiff
That's what she said...
the prothane motor mounts i have came from thunder and they work awesome. the shifter doesnt move around anymore and the engine is dead still. i'm pretty sure they cause LESS vibration as well, not sure how this works, but it definatly feels better. i'm also running a new OEM trans mount.
the synergy(?) suspension piece from autozone is a great piece but some people report vibration and ditch for an OEM. only problem w/ the OEM is that they cost over 70$
Originally Posted by TheBlurLS1
^^ this is uncalled for, really makes people want to reply to your thread! ^^
Unfortunately, I found some threads saying that the prothanes were equally as harsh. Oh well, as long as this new tranny mount solves my y-pipe banging...
Originally Posted by kpowr82
That's why I went with the prothane. I was hearing a lot about the ES mounts transferred too much vibration into the cabin.
i have TSP duals on my car. the leg that connects to the drivers side header runs LESS THAN 1/4" from that floorboard crossmember that i forgot to flatten out
it NEVER HITS THE FLOOR, even running 315 nitto drags and 4.11 gears with a dead hook 1st gear rhomp
so yes i'd say the poly motor mounts work pretty well
Originally Posted by strokedls1
Solids are not the way to go. The block will distort on hard launches. Don't get the poly mounts unless you are trying to correct something. Stockers are fine.
