What's considered a bolt-on?
Old 04-15-2005, 10:01 AM
11Second Club
Gauge's Avatar
Default What's considered a bolt-on?
Like the title says, I'm curious what people consider bolt-ons. The following I pretty much assume are "bolt-ons":
- Exhaust
- Induction (lid, bellows, TB, filter, and MAF)
- Pulleys
- Suspension
But are these?
- Springs/rockers
- Cam
- Heads
- Pushrods
- Intake manifold
Old 04-15-2005, 10:19 AM
Rok
Rok's Avatar
I consider the intake a bolt-on, maybe the springs/rockers and pushrods could be. but the heads and cam are not.
Old 04-15-2005, 10:31 AM
LS1TECH Sponsor
Steve Burger's Avatar
Normally, anything that does not touch oil. The exceptions are springs and rockers.
Realistically, whatever someone will believe.
Old 04-15-2005, 11:43 AM
gettinthere's Avatar
My thoughts exactly. I say if you have to crack open the motor (intake manifold excluded) it's not a bolt on.
Old 04-15-2005, 12:34 PM
snake charmer's Avatar
Old 04-15-2005, 01:18 PM
blkZ28spt's Avatar
I don't even consider rockers a bolt-on. If it touches engine oil or is a power adder it's not a bolt-on. As for the rockers, think about it. You can add high ratio rockers that increase the lift of the cam, yet a cam isn't a bolt-on. Doesn't quite make sense to consider it a bolt-on IMO.
Old 04-15-2005, 01:20 PM
00Z28 Camaro's Avatar
depends how you look at it , I can " bolt on" a supercharger
Old 04-15-2005, 01:21 PM
blkZ28spt's Avatar
I guess if you just ignore or significantly alter the definition of a bolt-on.
Old 04-15-2005, 01:25 PM
Wnts2Go10O's Avatar
o god, this again... to be politically correct everything on a motor is a bolt on like bolting on a 408 or 422 twin 60 setup...
Old 04-15-2005, 03:08 PM
GuitsBoy's Avatar
Im with the strict definition that a bolton does not touch oil. A full bolton car may never have had a valve cover off. Although I would say gears are a bolton mod since its not touching engine oil, but gear oil. Now is a built TH400 and 4800 stall converter considered a bolton?
Old 04-15-2005, 03:21 PM
blkZ28spt's Avatar
I'd say a built TH400 and 4800 stall converter could be considered bolt-ons. Bolt-ons are usually power adding mods though. If it doesn't add power I don't think it can really be considered a "bolt-on", but is in another category of mods.
BBQLS1's Avatar
1. Valve covers must not be removed.
2. Everything, no farther than heads or cam.
3. Doesn't everything bolt on?
Old 04-15-2005, 03:24 PM
Nick D's Avatar
EXACTLY
Old 04-16-2005, 02:21 AM
Deamon2002's Avatar
There is definetly a fine line here, IMO though rockers are a bolton, but then again thats just my opinion. What makes me think this way is the ease of which this modification can be done. Remove coils, valve covers and unbolt the rocker arm plate. Tada! Bolt on the new rockers to the plate and bolt that on top of your valves. Springs on the other hand step further into that other side of the line. Pushrods are right on par with the rockers though, at least thats what I think.
Old 04-16-2005, 02:33 AM
blkZ28spt's Avatar
Ease of performing the mod doesn't/shouldn't have anything to do with it.
Old 04-16-2005, 05:12 AM
Deamon2002's Avatar
Again, just my opinion............
Old 04-16-2005, 06:02 AM
1FST99Z's Avatar
hell I dont see why everyone is being so picky. how I see it you have to bolt all of those on. so they are all bolt on's to me..
Old 04-16-2005, 12:01 PM
blkZ28spt's Avatar
Right. So then everything is a bolt-on. What would the point of that be?
Old 04-16-2005, 03:26 PM
Moderator
davered00ss's Avatar
Intake is a bolt on. Cam & springs is not.
Old 04-16-2005, 09:46 PM
psykoTA's Avatar
What is a stall considered?
I figured bolt-ons were quick and easy mods. Not extensive.
