View Poll Results: X-Pipe or H-Pipe
X-Pipe
42
82.35%
H-Pipe
9
17.65%
Voters: 51. You may not vote on this poll
X-Pipe VS. H-Pipe
Old 04-19-2005, 04:32 PM
silver02Z's Avatar
Default X-Pipe VS. H-Pipe
I done a search and came up with nothing so here we go. I'm going with true duals on my 02 Z28 and was wondering how many use X-Pipes and how many H-Pipes. I'm sure that the X-pipe is used more but what are the benifits over the H-Pipe?
I just spoke with a very respectable exhaust shop who has done countless true duals on these cars and he said he's used both H & X with little to no difference between the 2 other than the X is more $. Thanks in advance..
Kevin
Old 04-19-2005, 05:13 PM
OldeSkool's Avatar
I suspect that an H pipe will be easier/cheaper to come up with as well as provide clearance as the 2 pipes dont have to come together like an x, the crossover can be placed, bent, flattened easily enough to keep everything tucked up well. And then there's that thing about H-pipes being more rumbly
Old 04-19-2005, 05:21 PM
240M3SRT's Avatar
Whats the point of an H-pipe or the X-pipe? Does it make better power than just true duals?
Ive been into turbo 4 cyl cars too long can someone explain it to me. Thanks.
Old 04-19-2005, 05:44 PM
Hardtop00SS's Avatar
X pipe - better scavenging, more power, raw exhaust tone
H pipe - less power then X, more refined/mellow exhaust note
It's all in what you want..
Old 04-19-2005, 06:34 PM
OldeSkool's Avatar
a crossover helps equalize pressure from side to side... still, my favorite exhaust of all time would have to be 4 into 1 cobra side pipes... no crossover whatsoever, still makes good power and sounds plenty nice.
Old 04-19-2005, 07:19 PM
LS1Maniac's Avatar
Just to elaborate a little on what Hardtop00SS said.
X-pipe: Better scavenging, slightly larger hp increase, little louder exhaust tone, much more complicated and thusly costs more money to make, takes up more space than the H-pipe
H-pipe: Still scavenges but not as well as the X-pipe, slightly less hp increase than the X-pipe, has a deeper/smoother tone, is very simple to make, takes very little space and can fit in spaces the x-pipe can't, cheaper than the X-pipe
Straight pipes: No scavenging, no equalization of pressure between the two sides, less hp than either H or X-pipe, raspier/louder exhaust tone, cheapest of the true duals
I placed them in order of performance. Most people say that H-pipe setups sound better than X-pipes but the X-pipes outperform the H setups. It's all about what you're looking for. If you want the best possible sound go with the H-pipe, if you want the best possible performance go with the X-pipe.
Old 04-19-2005, 08:41 PM
silver02Z's Avatar
How much HP difference are we talking about between X & H...Is it noticable SOTP?
Old 04-19-2005, 08:43 PM
LS1Maniac's Avatar
1-5 hp and 1-5 tq max.
Old 04-19-2005, 09:25 PM
Swang's Avatar
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
heres how it works on stangs, so im assuming the same is true here.
H pipe- more low end power (torque), "american muscle sound"
X Pipe,- more power uptop (horsepower) "ferarri sounding"
its all in what you want. Remember that HP isnt everything, Torque is more important.
"horsepower sells cars, but torque wins races"-Carroll Shelby
Old 04-19-2005, 09:27 PM
240M3SRT's Avatar
Every little bit counts sounds like i will be doing an x-pipe. Any good links to get a 3" or so x-pipe ss or mild steel well priced?
Old 04-19-2005, 09:28 PM
Swang's Avatar
adding to my last post...theres benefits to both, thats why they are both still around, so there is no one that is "better" than the other, its all in what oyu want
Old 01-05-2006, 02:37 PM
V6 Bird's Avatar
yes its noticeable...the X is far more responsive in the low to midrange.
Old 01-05-2006, 02:50 PM
V6 Bird's Avatar
to refine your post a little more........usable power wins races.
Old 01-05-2006, 07:28 PM
realmendrivev8s's Avatar
Does anybody hae a dyno chart or something that shows the difference in tq and hp curves between h and x pipe setups
Old 01-05-2006, 08:12 PM
99Hawk262's Avatar
I have an H-pipe and I noticed a significant increase in my low and mid-range power. The most noticeable difference was in the top-end, but low and mid-range was definitely increased.
Old 01-05-2006, 08:26 PM
MountainMotor's Avatar
Yea, I've always thought that the H-pipe gives a bit more low-end and the X-pipe gives a bit more high-end. I personally like the H-pipes better because of the low-end and sound but it's all in personal opinion.
Old 01-06-2006, 10:16 AM
dug
dug's Avatar
Im skeptical about power increases from xpipes and hpipes. Drag cars just run open headers.
Old 01-06-2006, 06:27 PM
Im leaning more towards a H pipe setup since i think they sound better and i am more worried about low end power.
Old 01-07-2006, 08:25 PM
MadBill's Avatar
But street cars need mufflers, and unless you have room to stick a couple of big mostly empty boxes like Flowmasters or Spin Techs under the front seat, just where the tuned collector lengths should end, you lose power, especially with a big cam. Dr. Gas, originator of the X-pipe, says the tuned length ends at the crossover hole, but that the energy transferred from one side to the other can make better power over a wider band than open headers and that past the 'X', the pressure pulses are mild and the exhaust sizing requirement is much less.
Old 01-07-2006, 08:50 PM
00SLPSS's Avatar
I have an H pipe on my car right now and I just ordered my texas-speed true duals with an X.
Once I get that on there I'll let you know the differences. My current setup has bullets and the new one will have sweet thunder mufflers, IDK if that will affect anything other than sound.
Quick Reply: X-Pipe VS. H-Pipe
