i cant break the crank bolt loose during cam swap, HELP~!
Old 04-20-2005, 10:19 PM
LS1_PNYTAMR's Avatar
Default i cant break the crank bolt loose during cam swap, HELP~!
i assumed from reading the ls1howto guide u just wedge in a screwdriver in teh flex plate, and get a breaker bar with some pipe, but how hard am i supposed to damn pull????????
Old 04-20-2005, 10:23 PM
Cal
Cal's Avatar
Naw, here's what you do: put a long handled breaker bar on the bolt, and lay the handle on the front frame rail on the driver side. Or if you haven't raised the car, you can put the handle against the floor, but on the driver side. Pull the ignition fuse . . . then turn the ignition key to start for about one fulll second, and you're done. Dealer shop does it the same way.
98Grnz28's Avatar
do you have auto or man,? A impact is the easiest way to get it off. You have to pull hard. I had to use a cheater bar.
sandking's Avatar
It's a pain in the ***!! I had a pipe on the end of a breaker bar. I used a 3/8 extension in the flex plate.
Old 04-20-2005, 10:24 PM
sandking's Avatar
Wow!! 3 posts at the same time
Old 04-20-2005, 10:27 PM
98Grnz28's Avatar
Or do what cal said.
Old 04-20-2005, 10:31 PM
Cal
Cal's Avatar
Or do what 98Grmz28 said
Old 04-20-2005, 10:33 PM
well i pulled the starter like ls1howto.com said.. did ya'll stick the damn screwdirver or 3/8's extension in thru a hole in the flex plate where the starter drops down there.. or on the back side where that lil cover is at?
ive dropped the starter, in otherwords, i still something metal thru on of the holes around the outside of my tci flexplate, thus holding it still... then i get the biggest ******* piece of pipe i can find and throw all my 170lbs into it?
Old 04-20-2005, 10:43 PM
Krab's Avatar
Use a 1/2" drive 24" breaker bar with the 24mm deep impact socket, you're done. If you can't do it like that, go lift some weights, then get back to the crank bolt when you're ready.
Old 04-20-2005, 10:46 PM
my problem is i cant get the ******* flex plate still.....!!!!
Old 04-20-2005, 10:47 PM
bigdsz's Avatar
How about an impact wrench!!!
Old 04-20-2005, 11:15 PM
luv2spd's Avatar
I just used an impact wrench to break mine loose but was sure to use a tq. wrench to tighten it back up.
Old 04-20-2005, 11:30 PM
01_SuperSlow's Avatar
You just need a 3 foot pipe and the right leverage.
If you're trying to do it from underneath, try it from the top. It was a lot easier for me from the top.
Old 04-20-2005, 11:56 PM
Cal
Cal's Avatar
That's why I said to put the wrench against the frame and let the starter turn it loose.
Old 04-21-2005, 07:06 AM
777's Avatar
cal's idea works with any tranmission as long as it's nuetral/park
Old 04-21-2005, 07:14 AM
Z06 Steve's Avatar
you guys are doing it the caveman way! get a air gun and it comes right off in 2min.
Old 04-21-2005, 08:13 AM
98 Silver Bullet's Avatar
I could not get mine out after installing it with locktite. If you go to Locktite's website they will give the information on what temperature to heat it to in order to get to break loose. I heated the head of the bolt with a rosebud, let it cool a little and the bolt came right out with very little effort.
Old 04-21-2005, 09:30 AM
Derek98z's Avatar
worst case scenario, since you have the starter out, go buy a flywheel locking tool. That's how I get flywheels bolted on and off when the tranny isn't attached. Same works for crank bolts
Old 04-21-2005, 03:15 PM
RGR Pete's Avatar
I'm not a big fan of taking alot of stuff off. Take a small pry bar and wedge it through the opening in the pulley, then get a 1/2 inch braker bar and turn. My pulley swap was so easy, I went back and re-read all the posts on it. Impact gun won't fit with work.
