Questions About putting a 02 LS1 into a 98z28?
Will i be able to put a 02 WS6 LS1 with a LS6 block into my car without having problems with parts not matching? its a long block. I have a 98z28 ls1 with blown motor which cant be rebuilt. So i was looking at perhaps getting a LS6 intake with EGR provisions so i can keep my car legal. The 02 engine has 25k on it v.s my blown 93k motor. Thanks
Nice car VSG looks good. I hope someone post what sensor it is i want to make sure i have everything i need to get it back up and running. Also who makes a LS6 intake that has EGR i think i seen that SLP does any other companys make one that does? Thanks
2 things you'll have to change if your running the 98 computer. 98s have a different coolant temp sensor, and you will have to put in the 98 injectors, or scale your IFR table accordingly if you use the 02 injectors. everything else should be plug and play.
Frank
Frank
So what temp sensor do i use a 01-02 sensor or the 98-00 sensor? Ill just swap over my 98z fuel injectors. Also are the water pump and oil pump the same? ill probably get new parts for it when i get it. Also what headers would u guys recommend? i hear macs are pretty good. Thanks
