.62 sixth gear in 2001 T/A
UNDER PRESSURE MOD
An even better question is can you change first gear to the Z06 ratio (I beleive its 2.9x as opposed to 2.6). This way if you have 3.73s, its like having 4.10s in first but without the risk of blowing the 4.10s (factory 10-bolt of course) or losing the gas mileage and drivability for the rest of the gears. I had 4.10s and hated them... was constantly shifting or skipping gears on purpose around town.
I would like to .62 sixth because with 3.42 gears, light flywheel/clutch, and a 231/237 cam, sixth gear is pretty much useless. I would like to put 3.23 gears in to drop the rpm in open road races, but that makes sixth exen more useless.
A lower first would be great, but....
